Updated on 2026-08-14 GMT+08:00
Configuring an Object ACL (SDK for Go)
Function
Access control lists (ACLs) allow resource owners to grant other accounts the permissions to access resources. By default, only the resource owner has full control over resources when a bucket or object is created. That is, the bucket creator has full control over the bucket, and the object uploader has full control over the object. Other accounts do not have the permissions to access resources. If resource owners want to grant other accounts the read and write permissions on resources, they can use ACLs. ACLs grant permissions to accounts. After an account is granted permissions, both the account and its IAM users can access the resources. For more information, see ACLs. Even if an ACL is set for an object encrypted using SSE-KMS, the cross-tenant access is unavailable.
You can set an ACL when uploading an object or call an ACL API to modify or obtain the ACL of an existing object.
Restrictions
Method
func (obsClient ObsClient) SetObjectAcl(input *SetObjectAclInput) (output *BaseModel, err error)
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
input
*SetObjectAclInput
Yes
Explanation:
Input parameters for configuring an ACL for the object. For details, see Table 2.
Table 2 SetObjectAclInput
Type
Mandatory (Yes/No)
Bucket
string
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name must be unique across all accounts and regions.
  • A bucket name:
    • Must be 3 to 63 characters long and start with a digit or letter. Lowercase letters, digits, hyphens (-), and periods (.) are allowed.
    • Cannot be formatted as an IP address.
    • Cannot start or end with a hyphen (-) or period (.).
    • Cannot contain two consecutive periods (..), for example, my..bucket.
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Default value:
None
Key
string
Yes
Explanation:
Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name.
For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt.
Value range:
The value must contain 1 to 1,024 characters.
Default value:
None
VersionId
string
No
Explanation:
Object version ID, for example, G001117FCE89978B0000401205D5DC9A
Value range:
The value must contain 32 characters.
Default value:
None
ACL
AclType
No
Explanation:
Pre-defined ACL.
Value range:
See Table 3.
Default value:
None
Owner
Owner
No
Explanation:
Account ID of the object owner. For details, see Table 4.
Restrictions:
Owner and Grants must be used together and they cannot be used with ACL.
Grants
[]Grant
No
Explanation:
Grantees' permission information. For details, see Table 5.
Default value:
None
Table 3 AclType
Constant
Default Value
AclPrivate
private
Private read/write
A bucket or object can only be accessed by its owner.
AclPublicRead
public-read
Public read and private write
If this permission is granted on a bucket, anyone can read the object list, multipart tasks, metadata, and object versions in the bucket.
If it is granted on an object, anyone can read the content and metadata of the object.
AclPublicReadWrite
public-read-write
Public read/write
If this permission is granted on a bucket, anyone can read the object list, multipart tasks, metadata, and object versions in the bucket, and can upload or delete objects, initiate multipart upload tasks, upload parts, assemble parts, copy parts, and abort multipart upload tasks.
AclPublicReadDelivered
public-read-delivered
Public read on a bucket as well as objects in the bucket
If this permission is granted on a bucket, anyone can read the object list, multipart tasks, metadata, and object versions, and read the content and metadata of objects in the bucket.
AclPublicReadDelivered does not apply to objects.
AclPublicReadWriteDelivered
public-read-write-delivered
Public read/write on a bucket as well as objects in the bucket
If this permission is granted on a bucket, anyone can read the object list, multipart uploads, metadata, and object versions in the bucket, and can upload or delete objects, initiate multipart upload tasks, upload parts, assemble parts, copy parts, and abort multipart uploads. They can also read the content and metadata of objects in the bucket.
AclPublicReadWriteDelivered does not apply to objects.
AclBucketOwnerFullControl
bucket-owner-full-control
If this permission is granted on an object, only the bucket and object owners have the full control over the object.
By default, if you upload an object to a bucket of any other user, the bucket owner does not have the permissions on your object. After you grant this permission to the bucket owner, the bucket owner can have full control over your object.
Table 4 Owner
Type
Mandatory (Yes/No)
ID
string
Yes if used as a request parameter
Explanation:
Account (domain) ID of the owner
Value range:
To obtain the account ID, see How Do I Get My Account ID and User ID?
Table 5 Grant
Type
Mandatory (Yes/No)
Grantee
Grantee
Explanation:
Grantee information. For details, see Table 6.
Permission
PermissionType
Explanation:
Granted permission
Value range:
See Table 7.
Default value:
None
Table 6 Grantee
Type
Mandatory (Yes/No)
Type
GranteeType
Explanation:
Grantee type
Value range:
See Table 8.
Default value:
None
ID
string
Yes if this parameter is used as a request parameter and Type is set to GranteeUser
Explanation:
Account (domain) ID of the grantee
Value range:
Default value:
None
DisplayName
string
No if used as a request parameter
Explanation:
Account name of the grantee
Restrictions:
  • Starts with a letter.
  • Contains 6 to 32 characters.
  • Contains only letters, digits, hyphens (-), or underscores (_).
Default value:
None
URI
GroupUriType
Yes if this parameter is used as a request parameter and Type is set to GranteeGroup
Explanation:
Authorized user group
Value range:
See Table 9.
Default value:
None
Table 7 PermissionType
Constant
Default Value
PermissionRead
READ
Read permission
PermissionWrite
WRITE
Write permission
PermissionReadAcp
READ_ACP
Permission to read ACL configurations
PermissionWriteAcp
WRITE_ACP
Permission to modify ACL configurations
PermissionFullControl
FULL_CONTROL
Full control access, including read and write permissions for a bucket and its ACL, or for an object and its ACL.
Table 8 GranteeType
Constant
Default Value
GranteeGroup
Group
User group
GranteeUser
CanonicalUser
Individual user
Table 9 GroupUriType
Constant
Default Value
GroupAllUsers
AllUsers
All users
Responses
Table 10 List of returned results
Type
output
*BaseModel
Explanation:
Returned results. For details, see Table 11.
err
error
Explanation:
Error messages returned by the API
Table 11 BaseModel
Type
StatusCode
int
Explanation:
HTTP status code
Restrictions:
None
Value range:
A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code.
Default value:
None
RequestId
string
Explanation:
Request ID returned by the OBS server
Restrictions:
None
Value range:
None
Default value:
None
ResponseHeaders
map[string][]string
Explanation:
HTTP response headers
Restrictions:
None
Value range:
None
Default value:
None
Code Examples
This example sets the ACL of object example/objectname to Private.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
package main
import (
    "fmt"
    "os"
    obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs"
func main() {
    //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
    //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
    ak := os.Getenv("AccessKeyID")
    sk := os.Getenv("SecretAccessKey")
    // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
    securityToken := os.Getenv("SecurityToken")
    // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
    endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com"
    // Create an obsClient instance.
    // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance.
    obsClient, err := obs.New(ak, sk, endPoint, obs.WithSecurityToken(securityToken))
    if err != nil {
        fmt.Printf("Create obsClient error, errMsg: %s", err.Error())
    input := &obs.SetObjectAclInput{}
    // Specify a bucket name.
    input.Bucket = "examplebucket"
    // Specify an object (example/objectname as an example).
    input.Key = "example/objectname"
    // Set the object ACL to Private.
    input.ACL = obs.AclPrivate
    // Configure the object ACL.
    output, err := obsClient.SetObjectAcl(input)
    if err == nil {
        fmt.Printf("Set Object(%s)'s acl successful with Bucket(%s)!\n", input.Key, input.Bucket)
        fmt.Printf("RequestId:%s\n", output.RequestId)
        return
    fmt.Printf("Set Object(%s)'s acl fail with Bucket(%s)!\n", input.Key, input.Bucket)
    if obsError, ok := err.(obs.ObsError); ok {
        fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.")
        fmt.Println(obsError.Error())
    } else {
        fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.")
        fmt.Println(err)
