Deleting an Object (SDK for Go)
Function
This API deletes an object in the specified bucket to save space and costs.
Restrictions
- To delete an object, you must be the bucket owner or have the required permission (obs:object:DeleteObject in IAM or DeleteObject in a bucket policy).
 - The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
 - If versioning is not enabled for a bucket, deleted objects cannot be recovered.
Method
func (obsClient ObsClient) DeleteObject(input *DeleteObjectInput) (output *DeleteObjectOutput, err error)
Request Parameters
        Parameter  |
        Type  |
        Mandatory (Yes/No)  |
        Description  |
        input  |
        Yes  |
        Request parameters for deleting an object  |
        Parameter  |
        Type  |
        Description  |
        Bucket  |
        string  |
        Yes  |
        Explanation: Bucket name Restrictions:
 Default value: None  |
        Key  |
        string  |
        Yes  |
        Explanation: Target object name An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None  |
        VersionId  |
        string  |
        No  |
        Explanation: ID of the object version to delete, for example, G001117FCE89978B0000401205D5DC9 Value range: The value must contain 32 characters. Default value: None. If this parameter is left blank, the latest version of the object is deleted.  |
Responses
        Parameter  |
        Type  |
        Description  |
        output  |
        Explanation: Returned results. For details, see Table 4.  |
        err  |
        error  |
        Explanation: Error messages returned by the API  |
        Parameter  |
        Type  |
        Description  |
        StatusCode  |
        int  |
        Explanation: HTTP status code Value range: A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None  |
        RequestId  |
        string  |
        Explanation: Request ID returned by the OBS server Default value: None  |
        ResponseHeaders  |
        map[string][]string  |
        Explanation: HTTP response headers Default value: None  |
        DeleteMarker  |
        bool  |
        Explanation: Whether the deleted object is a delete marker Value range:
 Default value: false  |
        VersionId  |
        string  |
Code Examples
This example deletes object example/objectname from bucket examplebucket.
        1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42  |
        package main import ( "fmt" "os" obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs" ) func main() { //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html. ak := os.Getenv("AccessKeyID") sk := os.Getenv("SecretAccessKey") // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // securityToken := os.Getenv("SecurityToken") // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com" // Create an obsClient instance. // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance. obsClient, err := obs.New(ak, sk, endPoint/*, obs.WithSecurityToken(securityToken)*/) if err != nil { fmt.Printf("Create obsClient error, errMsg: %s", err.Error()) } input := &obs.DeleteObjectInput{} // Specify a bucket name. input.Bucket = "examplebucket" // Specify the object (example/objectname as an example) to delete. input.Key = "example/objectname" // Delete the object. output, err := obsClient.DeleteObject(input) if err == nil { fmt.Printf("Delete object(%s) under the bucket(%s) successful!\n", input.Key, input.Bucket) fmt.Printf("RequestId:%s\n", output.RequestId) return } fmt.Printf("Delete object(%s) under the bucket(%s) fail!\n", input.Key, input.Bucket) if obsError, ok := err.(obs.ObsError); ok { fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.") fmt.Println(obsError.Error()) } else { fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.") fmt.Println(err) } }  |
