Help Center/ Object Storage Service/ SDK Reference/ Go/ Buckets (SDK for Go)/ Obtaining the Static Website Hosting Configuration of a Bucket (SDK for Go)
Updated on 2025-05-12 GMT+08:00
Function
You can host static website resources such as HTML web pages, flash files, as well as audio and video files in an OBS bucket, so that you can access these hosted resources using the bucket's website endpoint. Typical use cases include:
  • Redirecting all requests to another website
  • Redirecting specific requests
This API returns the static website hosting configuration of the bucket.
Restrictions
Method
func (obsClient ObsClient) GetBucketWebsiteConfiguration(bucketName string) (output *GetBucketWebsiteConfigurationOutput, err error)
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
bucketName
string
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name must be unique across all accounts and regions.
  • A bucket name:
    • Must be 3 to 63 characters long and start with a digit or letter. Lowercase letters, digits, hyphens (-), and periods (.) are allowed.
    • Cannot be formatted as an IP address.
    • Cannot start or end with a hyphen (-) or period (.).
    • Cannot contain two consecutive periods (..), for example, my..bucket.
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Default value:
None
Responses
Table 2 List of returned results
Type
output
Explanation:
Returned results. For details, see Table 3.
err
error
Explanation:
Error messages returned by the API
Table 3 GetBucketWebsiteConfigurationOutput
Type
StatusCode
int
Explanation:
HTTP status code
Value range:
A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code.
Default value:
None
RequestId
string
Explanation:
Request ID returned by the OBS server
Default value:
None
ResponseHeaders
map[string][]string
Explanation:
HTTP response headers
Default value:
None
RedirectAllRequestsTo
RedirectAllRequestTo
Explanation:
Redirection rule of all requests For details, see Table 4.
IndexDocument
IndexDocument
Explanation:
Default page configuration. For details, see Table 5.
ErrorDocument
ErrorDocument
Explanation:
Error page configuration. For details, see Table 6.
RoutingRules
[]RoutingRule
Explanation:
Redirection rule list For details, see Table 7.
Table 4 RedirectAllRequestsTo
Type
HostName
string
Explanation:
Host name used for redirection, for example, www.example.com
Restrictions:
The host name must be in the standard host name format.
Default value:
None
Protocol
ProtocolType
Explanation:
Protocol used for redirection
Value range:
See Table 10.
Default value:
None
Table 5 IndexDocument
Type
Mandatory (Yes/No)
Suffix
string
Yes if IndexDocument is specified
Explanation:
Suffix that is appended to the request for a directory. For example, if the suffix is index.html and you request samplebucket/images/, the returned data will be for the object named images/index.html in the bucket samplebucket.
Value range:
This parameter can neither be left blank nor contain slashes (/).
Default value:
None
Table 6 ErrorDocument
Type
Mandatory (Yes/No)
Key
string
No if ErrorDocument is specified
Explanation:
Object name to use when a 4XX error occurs. This parameter specifies the webpage to display when an error occurs.
Value range:
The value must contain 1 to 1,024 characters.
Default value:
None
Table 7 RoutingRule
Type
Condition
Condition
Explanation:
Conditions that must be met for the specified redirect to apply
Value range:
See Table 8.
Default value:
None
Redirect
Redirect
Explanation:
Details about the redirect request. For details, see Table 9.
Table 8 Condition
Type
Mandatory (Yes/No)
KeyPrefixEquals
string
No
Explanation:
Object name prefix when the redirection is applied. When a request is sent for accessing an object, the redirection rule takes effect if the object name prefix matches the value specified for this parameter.
For example, to redirect the request for object ExamplePage.html, set the KeyPrefixEquals to ExamplePage.html.
Restrictions:
This parameter cannot be used together with HttpErrorCodeReturnedEquals.
Value range:
Default value:
None
string
No
Explanation:
HTTP error codes when the redirection takes effect. The specified redirection is applied only when the error code returned equals the value specified for this parameter.
For example, if you want to redirect requests to NotFound.html when HTTP error code 404 is returned, set HttpErrorCodeReturnedEquals to 404 in Condition, and set ReplaceKeyWith to NotFound.html in Redirect.
Restrictions:
This parameter cannot be used together with KeyPrefixEquals.
Value range:
See Error Codes.
Default value:
None
Table 9 Redirect
Type
Protocol
ProtocolType
Explanation:
Value range:
See Table 10.
Default value:
None
HostName
string
Explanation:
Default value:
None
ReplaceKeyPrefixWith
string
Explanation:
Object name prefix used for redirection
Value range:
Default value:
None
ReplaceKeyWith
string
Explanation:
Object name used for redirection
Restrictions:
This parameter cannot be used together with replaceKeyPrefixWith.
Value range:
Default value:
None
HttpRedirectCode
string
Explanation:
HTTP status code in the response to the redirect request. For details, see Status Code.
Default value:
None
Table 10 ProtocolType
Constant
Default Value
ProtocolHttp
http
HTTP protocol used for redirection
ProtocolHttps
https
HTTPS protocol used for the redirection request
Code Examples
This example returns the website configuration of bucket examplebucket.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
package main
import (
    "fmt"
    "os"
    obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs"
func main() {
    //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
    //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
    ak := os.Getenv("AccessKeyID")
    sk := os.Getenv("SecretAccessKey")
    // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
    // securityToken := os.Getenv("SecurityToken")
    // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
    endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com"
    // Create an obsClient instance.
    // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance.
    obsClient, err := obs.New(ak, sk, endPoint/*, obs.WithSecurityToken(securityToken)*/)
    if err != nil {
        fmt.Printf("Create obsClient error, errMsg: %s", err.Error())
    // Specify a bucket name.
    bucketname := "examplebucket"
    // Obtain the website configuration of the bucket.
    output, err := obsClient.GetBucketWebsiteConfiguration(bucketname)
    if err == nil {
        fmt.Printf("Get bucket(%s)'s website configuration successful!\n", bucketname)
        fmt.Printf("Get bucket metadata successful!\n")
        fmt.Printf("RequestId:%s\n", output.RequestId)
        fmt.Printf("Suffix:%s\n", output.IndexDocument.Suffix)
        fmt.Printf("Key:%s\n", output.ErrorDocument.Key)
        for index, routingRule := range output.RoutingRules {
            fmt.Printf("Condition[%d]-KeyPrefixEquals:%s, HttpErrorCodeReturnedEquals:%s\n",
                index, routingRule.Condition.KeyPrefixEquals, routingRule.Condition.HttpErrorCodeReturnedEquals)
            fmt.Printf("Redirect[%d]-Protocol:%s, HostName:%s, ReplaceKeyPrefixWith:%s, HttpRedirectCode:%s\n",
                index, routingRule.Redirect.Protocol, routingRule.Redirect.HostName, routingRule.Redirect.ReplaceKeyPrefixWith, routingRule.Redirect.HttpRedirectCode)
        return
    fmt.Printf("Get bucket(%s)'s website configuration fail!\n", bucketname)
    if obsError, ok := err.(obs.ObsError); ok {
        fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.")
        fmt.Println(obsError.Error())
    } else {
        fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.")
        fmt.Println(err)
