Help Center/ Object Storage Service/ SDK Reference/ Go/ Buckets (SDK for Go)/ Obtaining the Bucket ACL (SDK for Go)
Updated on 2025-05-12 GMT+08:00
Function
Access control lists (ACLs) allow resource owners to grant other accounts the permissions to access resources. By default, only the resource owner has full control over resources when a bucket or object is created. That is, the bucket creator has full control over the bucket, and the object uploader has full control over the object. Other accounts do not have the permissions to access resources. If resource owners want to grant other accounts the read and write permissions on resources, they can use ACLs. ACLs grant permissions to accounts. After an account is granted permissions, both the account and its IAM users can access the resources. For more information, see ACLs.
This API returns the ACL of a bucket.
Restrictions
Method
func (obsClient ObsClient) GetBucketAcl(bucketName string) (output *GetBucketAclOutput, err error)
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
bucketName
string
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name must be unique across all accounts and regions.
  • A bucket name:
    • Must be 3 to 63 characters long and start with a digit or letter. Lowercase letters, digits, hyphens (-), and periods (.) are allowed.
    • Cannot be formatted as an IP address.
    • Cannot start or end with a hyphen (-) or period (.).
    • Cannot contain two consecutive periods (..), for example, my..bucket.
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Default value:
None
Responses
Table 2 List of returned results
Type
output
*GetBucketAclOutput
Explanation:
Returned results. For details, see Table 3.
err
error
Explanation:
Error messages returned by the API
Table 3 GetBucketAclOutput
Type
StatusCode
int
Explanation:
HTTP status code
Value range:
A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code.
Default value:
None
RequestId
string
Explanation:
Request ID returned by the OBS server
Default value:
None
ResponseHeaders
map[string][]string
Explanation:
HTTP response headers
Default value:
None
Owner
Owner
Explanation:
Bucket owner. For details, see Table 4.
Grants
Grant
Explanation:
Grantees' permission information. For details, see Table 5.
Table 4 Owner
Type
Mandatory (Yes/No)
ID
string
Yes if used as a request parameter
Explanation:
Account (domain) ID of the owner
Value range:
To obtain the account ID, see How Do I Get My Account ID and User ID?
Default value:
None
Table 5 Grant
Type
Grantee
Grantee
Explanation:
Grantee information. For details, see Table 6.
Permission
PermissionType
Explanation:
Granted permission. For details, see Table 9.
Table 6 Grantee
Type
Type
GranteeType
Explanation:
Grantee type
Value range:
See Table 7.
Default value:
None
ID
string
Explanation:
Account (domain) ID of the grantee
Value range:
Default value:
None
DisplayName
string
Explanation:
Account name of the grantee
Restrictions:
  • Starts with a letter.
  • Contains 6 to 32 characters.
  • Contains only letters, digits, hyphens (-), or underscores (_).
Default value:
None
URI
GroupUriType
Explanation:
Authorized user group
Value range:
See Table 8.
Default value:
None
Table 7 GranteeType
Constant
Default Value
GranteeGroup
Group
User group
GranteeUser
CanonicalUser
Individual user
Table 8 GroupUriType
Constant
Default Value
GroupAllUsers
AllUsers
All users
Table 9 PermissionType
Constant
Default Value
PermissionRead
READ
Read permission
PermissionWrite
WRITE
Write permission
PermissionReadAcp
READ_ACP
Permission to read ACL configurations
PermissionWriteAcp
WRITE_ACP
Permission to modify ACL configurations
PermissionFullControl
FULL_CONTROL
Full control access, including read and write permissions for a bucket and its ACL, or for an object and its ACL.
Code Examples
This example shows how to obtain the ACL of the examplebucket bucket.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
package main
import (
    "fmt"
    "os"
    obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs"
func main() {
    //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
    //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
    ak := os.Getenv("AccessKeyID")
    sk := os.Getenv("SecretAccessKey")
    // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
    // securityToken := os.Getenv("SecurityToken")
    // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
    endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com"
    // Create an obsClient instance.
    // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance.
    obsClient, err := obs.New(ak, sk, endPoint, obs.WithSignature(obs.SignatureObs)/*, obs.WithSecurityToken(securityToken)*/)
    if err != nil {
        fmt.Printf("Create obsClient error, errMsg: %s", err.Error())
    // Specify a bucket name.
    bucketname := "examplebucket"
    // Obtain the bucket ACL.
    output, err := obsClient.GetBucketAcl(bucketname)
    if err == nil {
        fmt.Printf("Get bucket(%s)'s acl rules successful!\n", bucketname)
        fmt.Printf("RequestId:%s\n", output.RequestId)
        fmt.Printf("Owner.ID:%s\n", output.Owner.ID)
        for index, grant := range output.Grants {
            fmt.Printf("Grant[%d]-Type:%s, ID:%s, URI:%s, Permission:%s\n",
                index, grant.Grantee.Type, grant.Grantee.ID, grant.Grantee.URI, grant.Permission)
        return
    fmt.Printf("Get bucket(%s)'s acl rules fail!\n", bucketname)
    if obsError, ok := err.(obs.ObsError); ok {
        fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.")
        fmt.Println(obsError.Error())
    } else {
        fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.")
        fmt.Println(err)
