Configuring a Storage Class for a Bucket (SDK for Go)
Function
OBS offers the following storage classes: Standard, Infrequent Access, and Archive. For details, see Storage Classes.
This API configures a storage class for a bucket. If you do not specify a storage class when uploading or copying an object, or initiating a multipart upload, the object will inherit the bucket's storage class.
Restrictions
- To configure a storage class for a bucket, you must be the bucket owner or have the required permission (obs:PutBucketStoragePolicy in IAM or PutBucketStoragePolicy in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
 - The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
func (obsClient ObsClient) SetBucketStoragePolicy(input *SetBucketStoragePolicyInput) (output *BaseModel, err error)
Request Parameters
        Parameter  |
        Type  |
        Mandatory (Yes/No)  |
        Description  |
        input  |
        Yes  |
        Explanation: Input parameters for configuring a bucket storage class. For details, see Table 2.  |
       Parameter  |
       Type  |
       Description  |
       Bucket  |
       string  |
       Yes  |
       Explanation: Bucket name Restrictions:
 Value range: The value must contain 3 to 63 characters. Default value: None  |
       StorageClass  |
       Yes  |
       Explanation: Storage class of the bucket Value range: For details about storage classes, see Table 3. Default value: None  |
       Constant  |
       Default Value  |
       Description  |
       StorageClassStandard  |
       STANDARD  |
       OBS Standard Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response.  |
       StorageClassWarm  |
       WARM  |
       OBS Infrequent Access Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but is instantly available when needed.  |
       StorageClassCold  |
       COLD  |
       OBS Archive Used for storing rarely accessed (once a year) data.  |
Responses
        Parameter  |
        Type  |
        Description  |
        output  |
        Explanation: Returned results. For details, see Table 5.  |
        err  |
        error  |
        Explanation: Error messages returned by the API  |
        Parameter  |
        Type  |
        Description  |
        StatusCode  |
        int  |
        Explanation: HTTP status code Value range: A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None  |
        RequestId  |
        string  |
        Explanation: Request ID returned by the OBS server Default value: None  |
        ResponseHeaders  |
        map[string][]string  |
        Explanation: HTTP response headers Default value: None  |
Code Examples
This example returns the storage class of bucket examplebucket.
        1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43  |
        package main import ( "fmt" "os" obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs" ) func main() { //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html. ak := os.Getenv("AccessKeyID") sk := os.Getenv("SecretAccessKey") // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // securityToken := os.Getenv("SecurityToken") // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com" // Create an obsClient instance. // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance. obsClient, err := obs.New(ak, sk, endPoint/*, obs.WithSecurityToken(securityToken)*/) if err != nil { fmt.Printf("Create obsClient error, errMsg: %s", err.Error()) } input := &obs.SetBucketStoragePolicyInput{} // Specify a bucket name. input.Bucket = "bucketname" // Specify a storage class (obs.StorageClassWarm as an example) for the bucket. input.StorageClass = obs.StorageClassWarm // Configure a storage class for the bucket. output, err := obsClient.SetBucketStoragePolicy(input) if err == nil { fmt.Printf("Set bucket(%s)'s storage-class successful!\n", input.Bucket) fmt.Printf("Set bucket storage-class successful!\n") fmt.Printf("RequestId:%s\n", output.RequestId) return } fmt.Printf("Set bucket(%s)'s storage-class fail!\n", input.Bucket) if obsError, ok := err.(obs.ObsError); ok { fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.") fmt.Println(obsError.Error()) } else { fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.") fmt.Println(err) } }  |
