Log Initialization (SDK for Go)
Function
You can enable the SDK log function to record log information generated during API calling into log files for subsequent data analysis or fault location. You can use InitLog to enable logging, CloseLog to disable logging, and SyncLog to synchronize log information from the cache to log files.
Initialization Method
func InitLog(logFullPath string, maxLogSize int64, backups int, level Level, logToConsole bool) error |
Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
logFullPath |
string |
Yes |
Full path to the log file |
maxLogSize |
int64 |
Yes |
Log file size in bytes |
backups |
int |
Yes |
Maximum number of log files that can be retained |
level |
Yes |
Log level |
logToConsole |
bool |
Yes |
Whether to print logs to the console Value options: true or false true: Logs are printed to the console. false: Logs are not printed to the console. Default value: false |
Constant |
Default Value |
Description |
LEVEL_OFF |
500 |
Close level. If this level is set, logging will be disabled. |
LEVEL_ERROR |
400 |
Error level. If this level is set, only error information will be printed. |
LEVEL_WARN |
300 |
Warning level. If this level is set, information about logs at the error level and information about partial critical events will be printed. |
LEVEL_INFO |
200 |
Information level. If this level is set, information about logs of the warning level, time consumed for each HTTP/HTTPS request, and time consumed for calling the ObsClient API will be printed. |
LEVEL_DEBUG |
100 |
Debugging level. If this level is set, information about logs at the information level, HTTP/HTTPS request and response headers, and stringToSign information calculated by authentication algorithm will be printed. |
Code Examples
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 |
// Import the dependency package. import ( obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs" ) func main() { // Set a path for saving log files. var logFullPath string = "./logs/OBS-SDK.log" // Set a size (in bytes) for each log file. var maxLogSize int64 = 1024 * 1024 * 10 // Set the number of retained log files. var backups int = 10 // Set a log level. var level = obs.LEVEL_INFO // Specify whether to print logs to OBS Console. var logToConsole bool = false // Enable logging. obs.InitLog(logFullPath, maxLogSize, backups, level, logToConsole) // Disable logging and synchronize cached data to log files. obs.CloseLog() } |
- The logging function is disabled by default. You need to enable it manually.
- For details about SDK logs, see Log Analysis.
- By default, logs are written to the cache (then written to log files after logs are accumulated to a certain amount). You can call obs.CloseLog() to forcibly synchronize the log information from the cache to log files.
