Obtaining the WORM Policy of a Bucket
Function
If a default WORM policy is configured for a bucket, you can call this API to obtain the default WORM policy of the bucket.
If you have never configured the default bucket-level retention policy after enabling WORM for a bucket, you can still use this API to check whether WORM is enabled.
Restrictions
- To obtain the WORM policy of a bucket, you must be the bucket owner or have the required permission (obs:bucket:GetBucketObjectLockConfiguration granted using IAM or GetBucketObjectLockConfiguration granted using a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
func (obsClient ObsClient) GetBucketWormConfiguration(BucketName *string) (output *GetBucketWormConfigurationOutput, err error)
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| BucketName | string | Yes | Explanation: Bucket name. Restrictions:
Default value: None |
Responses
| Parameter | Type | Description |
| output | Explanation: Returned results. For details, see Table 3. | |
| err | error | Explanation: The error message returned by the server. |
| StatusCode | int | Explanation: HTTP status code. Value range: A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
| RequestId | string | Explanation: Request ID returned by the OBS server. Default value: None |
| ResponseHeaders | map[string][]string | Explanation: HTTP response headers. Default value: None |
| ObjectLockEnabled | string | No Explanation: Bucket-level WORM status. Restrictions: N/A Value range: Enabled: Bucket-level WORM is enabled. Default value: N/A |
| Rule | *Rule | No Explanation: Bucket-level WORM policy. Restrictions: This parameter is mandatory when ObjectLockEnabled is set to Enabled. If this parameter is not specified, the default bucket-level WORM policy will be cleared. Value range: For details, see Table 4. Default value: N/A |
| DefaultRetention | Yes | Explanation: Bucket-level WORM policy. Restrictions: N/A Value range: For details, see Table 5. Default value: N/A |
| Mode | string | Yes | Explanation: WORM retention policy of a bucket. Restrictions: N/A Value range: COMPLIANCE: compliance mode Default value: N/A |
| Days | int | No | Explanation: Retention period, in days. Restrictions: Only one of Days and Years can be set to a value other than 0. The value must be within the allowed range. Value range: 1~36500 Default value: N/A |
| Years | int | No | Explanation: Default retention period, in years. Restrictions:
Value range: 1~100 Default value: N/A |
Sample Code
package main
import (
"fmt"
"os"
func main() {
// Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
// Obtain an AK/SK pair on the management console.
ak := os.Getenv("AccessKeyID")
sk := os.Getenv("SecretAccessKey")
// (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are not advised to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
securityToken := os.Getenv("SecurityToken")
// Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com"
// Create an obsClient instance.
// If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance.
obsClient, err := obs.New(ak, sk, endPoint, obs.WithSecurityToken(securityToken))
if err != nil {
fmt.Printf("Create obsClient error, errMsg: %s", err.Error())
input := &obs.GetBucketWormConfigurationInput{}
// Specify a bucket name.
input.Bucket = "examplebucket"
// Obtain the default WORM policy of the bucket.
output, err := obsClient.GetBucketWormConfiguration(input.Bucket)
if err == nil {
fmt.Printf("Get bucket(%s)'s WORM configuration successful!\n", input.Bucket)
fmt.Printf("ObjectLockEnabled: %s\n", output.ObjectLockEnabled)
if output.Rule != nil && output.Rule.DefaultRetention != nil {
fmt.Printf("DefaultRetention Mode: %s\n", output.Rule.DefaultRetention.Mode)
fmt.Printf("DefaultRetention Days: %d\n", output.Rule.DefaultRetention.Days)
fmt.Printf("RequestId:%s\n", output.RequestId)
return
fmt.Printf("Get bucket(%s)'s WORM configuration fail!\n", input.Bucket)
if obsError, ok := err.(obs.ObsError); ok {
fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.")
fmt.Println(obsError.Error())
} else {
fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.")
fmt.Println(err)
} What is your overall rating for this page?
