Updated on 2026-08-14 GMT+08:00
Configuring a WORM Policy for a Bucket
Function
OBS provides WORM in compliance mode. After a WORM policy is configured for a bucket, if no protection policy or retention period is set for newly uploaded objects, the bucket-level WORM policy will be automatically applied to these objects. You can call this API to configure a default protection policy and retention period for a bucket.
With a bucket's default WORM policy, if you do not specify a protection policy or retention period when you upload an object to the bucket, the default policy will be automatically applied to the newly uploaded object. An object-level WORM policy requires configuring a specific date, which indicates that an object will be protected until that date. For a default bucket-level WORM policy, a retention period is required, and the protection for an object starts when the object is uploaded to the bucket.
Restrictions
Method
func (obsClient ObsClient) SetBucketWormConfiguration(input *SetBucketDirectColdAccessInput) (output *BaseModel, err error)
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
input
*SetBucketWormConfigurationInput
Yes
Explanation:
Request parameters for configuring a WORM policy for a bucket. For details, see Table 2.
Table 2 SetBucketWormConfigurationInput
Type
Mandatory (Yes/No)
Bucket
string
Yes
Explanation:
Bucket name.
Restrictions:
  • A bucket name must be unique across all accounts and regions.
  • A bucket name:
    • Must be 3 to 63 characters long and start with a digit or letter. Lowercase letters, digits, hyphens (-), and periods (.) are allowed.
    • Cannot be formatted as an IP address.
    • Cannot start or end with a hyphen (-) or period (.).
    • Cannot contain two consecutive periods (..), for example, my..bucket.
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets with the same name in the same region, no error will be reported and the bucket properties comply with those set in the first creation request.
Default value:
None
ObjectLockConfiguration
Yes
Explanation:
Versioning status of the bucket.
Value range:
See Table 3.
Default value:
None
Table 3 ObjectLockConfiguration
Type
Mandatory (Yes/No)
ObjectLockEnabled
string
No
Explanation:
Bucket-level WORM status.
Restrictions:
N/A
Value range:
Enabled: Bucket-level WORM is enabled.
Default value:
N/A
Rule
*Rule
No
Explanation:
Bucket-level WORM policy.
Restrictions:
This parameter is mandatory when ObjectLockEnabled is set to Enabled. If this parameter is not specified, the default bucket-level WORM policy will be cleared.
Value range:
For details, see Table 4.
Default value:
N/A
Table 4 Rule
Type
Mandatory (Yes/No)
DefaultRetention
*DefaultRetention
Yes
Explanation:
Restrictions:
N/A
Value range:
For details, see Table 5.
Default value:
N/A
Table 5 DefaultRetention
Type
Mandatory (Yes/No)
Mode
string
Yes
Explanation:
WORM retention policy of a bucket.
Restrictions:
N/A
Value range:
COMPLIANCE: compliance mode
Default value:
N/A
Days
int
No
Explanation:
Retention period, in days.
Restrictions:
Only one of Days and Years can be set to a value other than 0. The value must be within the allowed range.
Value range:
1~36500
Default value:
N/A
Years
int
No
Explanation:
Default retention period, in years.
Restrictions:
  • One year is considered as 365 days, regardless of the leap year.
  • Only one of Days and Years can be set to a value other than 0. The value must be within the allowed range.
Value range:
1~100
Default value:
N/A
Responses
Table 6 List of returned results
Type
output
*BaseModel
Explanation:
Returned results. For details, see Table 7.
err
error
Explanation:
The error message returned by the server.
Table 7 BaseModel
Type
StatusCode
int
Explanation:
HTTP status code
Restrictions:
None
Value range:
A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code.
Default value:
None
RequestId
string
Explanation:
Request ID returned by the OBS server
Restrictions:
None
Value range:
None
Default value:
None
ResponseHeaders
map[string][]string
Explanation:
HTTP response headers
Restrictions:
None
Value range:
None
Default value:
None
Sample Code
This example configures a default WORM policy for bucket examplebucket.
package main
import (
    "fmt"
    "os"
    obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs"
func main() {
    // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
    // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
    ak := os.Getenv("AccessKeyID")
    sk := os.Getenv("SecretAccessKey")
    // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are not advised to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
    securityToken := os.Getenv("SecurityToken")
    // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
    endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com"
    // Create an obsClient instance.
    // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance.
    obsClient, err := obs.New(ak, sk, endPoint, obs.WithSecurityToken(securityToken))
    if err != nil {
        fmt.Printf("Create obsClient error, errMsg: %s", err.Error())
    input := &obs.SetBucketWormConfigurationInput{}
    // Specify a bucket name.
    input.Bucket = "examplebucket"
    // Specify a WORM policy.
    input.ObjectLockConfiguration.ObjectLockEnabled = "Enabled"
    input.ObjectLockConfiguration.Rule = &obs.Rule{}
    input.ObjectLockConfiguration.Rule.DefaultRetention = &obs.DefaultRetention{}
    input.ObjectLockConfiguration.Rule.DefaultRetention.Mode = "COMPLIANCE"
    input.ObjectLockConfiguration.Rule.DefaultRetention.Days = 30
    // Configure the default WORM policy for the bucket.
    output, err := obsClient.SetBucketWormConfiguration(bucketName)
    if err == nil {
	fmt.Printf("Set bucket(%s)'s WORM configuration successful!\n", bucketName)
	fmt.Printf("RequestId:%s\n", output.RequestId)
	return
    fmt.Printf("Set bucket(%s)'s WORM configuration fail!\n", bucketName)
    if obsError, ok := err.(obs.ObsError); ok {
	fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.")
	fmt.Println(obsError.Error())
    } else {
	fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.")
	fmt.Println(err)
