Updated on 2026-08-14 GMT+08:00
Configuring Direct Reading for a Bucket
Function
The direct reading function means that you can directly perform operations on Archive objects without restoring them.
By default, direct reading is disabled for a bucket.
This API is used to enable or disable direct reading for a bucket.
  • When direct reading is enabled on a bucket:
    • You can directly perform operations on the Archive objects in the bucket regardless of whether they have been restored.
    • Operations on the Archive objects that are not restored will be billed separately.
    • You need to restore objects in the bucket before you can operate them.
Direct reading means that you can directly perform operations on objects without restoring them. For more information about direct reading, see Direct Reading.
Restrictions
Method
func (obsClient ObsClient) SetBucketDirectColdAccess(input *SetBucketDirectColdAccessInput) (output *BaseModel, err error)
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
input
Yes
Explanation:
Request parameter for configuring direct reading for a bucket. For details, see Table 2.
Restrictions:
None
Value range:
None
Default value:
None
Table 2 SetBucketDirectColdAccessInput
Type
Mandatory (Yes/No)
Bucket
string
Yes
Explanation:
Bucket name.
Restrictions:
  • A bucket name must be unique across all accounts and regions.
  • A bucket name:
    • Must be 3 to 63 characters long and start with a digit or letter. Lowercase letters, digits, hyphens (-), and periods (.) are allowed.
    • Cannot be formatted as an IP address.
    • Cannot start or end with a hyphen (-) or period (.).
    • Cannot contain two consecutive periods (..), for example, my..bucket.
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets with the same name in the same region, no error will be reported and the bucket properties comply with those set in the first creation request.
Value range:
None
Default value:
None
DirectColdAccessConfiguration
Yes
Explanation:
Direct reading configuration of Archive objects in a bucket.
Restrictions:
None
Value range:
See Table 3.
Default value:
None
Table 3 DirectColdAccessConfiguration
Type
Mandatory (Yes/No)
Status
DirectColdAccessStatus
Yes
Explanation:
Direct reading status of a bucket
Restrictions:
None
Value range:
See Table 4.
Default value:
None
Table 4 DirectColdAccessStatus
Constant
Original Value
DirectColdAccessStatusEnabled
Enabled
Direct reading is enabled for the bucket.
DirectColdAccessStatusDisabled
Disabled
Direct reading is disabled for the bucket.
Responses
Table 5 List of returned results
Type
output
*BaseModel
Explanation:
Returned results. For details, see Table 6.
Value range:
None
err
error
Explanation:
The error message returned by the server.
Value range:
None
Table 6 BaseModel
Type
StatusCode
int
Explanation:
HTTP status code
Restrictions:
None
Value range:
A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code.
Default value:
None
RequestId
string
Explanation:
Request ID returned by the OBS server
Restrictions:
None
Value range:
None
Default value:
None
ResponseHeaders
map[string][]string
Explanation:
HTTP response headers
Restrictions:
None
Value range:
None
Default value:
None
Sample Code
This example configures direct reading for bucket examplebucket.
package main
import (
    "fmt"
    "os"
    obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs"
func main() {
    // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
    // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
    ak := os.Getenv("AccessKeyID")
    sk := os.Getenv("SecretAccessKey")
    // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are not advised to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
    securityToken := os.Getenv("SecurityToken")
    // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
    endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com"
    // Create an obsClient instance.
    // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance.
    obsClient, err := obs.New(ak, sk, endPoint, obs.WithSecurityToken(securityToken))
    if err != nil {
        fmt.Printf("Create obsClient error, errMsg: %s", err.Error())
    input := &obs.SetBucketDirectColdAccessInput{}
    // Specify a bucket name.
    input.Bucket = "examplebucket"
    // Specify the status.
    input.DirectColdAccessConfiguration.Status = obs.DirectColdAccessStatusEnabled
    // Configure direct reading for the bucket.
    output, err := obsClient.SetBucketDirectColdAccess(bucketName)
    if err == nil {
	fmt.Printf("Set bucket(%s)'s direct cold successful!\n", bucketName)
	fmt.Printf("RequestId:%s\n", output.RequestId)
	return
    fmt.Printf("Set bucket(%s)'s direct cold fail!\n", bucketName)
    if obsError, ok := err.(obs.ObsError); ok {
	fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.")
	fmt.Println(obsError.Error())
    } else {
	fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.")
	fmt.Println(err)
