Renaming an Object (SDK for Go)
Function
This API renames an object in the parallel file system (PFS).
Restrictions
- To rename an object, you must be the PFS owner or have the required permission (obs:bucket:PutObject in IAM or PutObject in a policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
- This API is currently available only for PFSs. Object buckets do not support this API. For details about how to create a PFS, see Creating a Parallel File System (SDK for Go).
Method
func (obsClient ObsClient) RenameFile(input *RenameFileInput) (output *RenameFileOutput, err error)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
input |
Yes |
Explanation: Request parameters for renaming an object. For details, see Table 2. |
Parameter |
Type |
Description |
Bucket |
string |
Yes |
Explanation: PFS name. Restrictions:
Default value: None |
Key |
string |
Yes |
Explanation: Directory name. It is the complete path of a directory in a PFS without the PFS name. For example, if the access path is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value can contain 1 to 1,024 characters. Default value: None |
NewObjectKey |
string |
Yes |
Explanation: Explanation: Name of the object after being renamed. An object is uniquely identified by an object name in a PFS. The object name does not contain the PFS name. For example, if the access path is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value can contain 1 to 1,024 characters. Default value: None |
Responses
Parameter |
Type |
Description |
output |
Explanation: Returned results. For details, see Table 4. |
err |
error |
Explanation: Error messages returned by the API |
Parameter |
Type |
Description |
StatusCode |
int |
Explanation: HTTP status code Value range: A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For more information, see Status Code. Default value: None |
RequestId |
string |
Explanation: Request ID returned by the OBS server Default value: None |
ResponseHeaders |
map[string][]string |
Explanation: HTTP response headers Default value: None |
Code Examples
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 |
package main import ( "fmt" "os" obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs" ) func main() { //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html. ak := os.Getenv("AccessKeyID") sk := os.Getenv("SecretAccessKey") // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. securityToken := os.Getenv("SecurityToken") // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here as an example. Replace it with the one currently in use. endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com" // Create an obsClient instance. // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance. obsClient, err := obs.New(ak, sk, endPoint, obs.WithSecurityToken(securityToken)) if err != nil { fmt.Printf("Create obsClient error, errMsg: %s", err.Error()) } input := &obs.RenameFileInput{} // Specify the name of the PFS. input.Bucket = "examplebucket" // Specify the source object name. folderName/originalObjectName is used as an example. input.Key = "folderName/originalObjectName" // Specify the new object name. newFolderName/newObjectName is used as an example. input.NewObjectKey = "newFolderName/newObjectName" // Rename the object. output, err := obsClient.RenameFile(input) if err == nil { fmt.Printf("Rename File(%s) successful with bucket(%s)!\n", input.Key, input.Bucket) fmt.Printf("RequestId:%s\n", output.RequestId) return } fmt.Printf("Rename File(%s) fail with bucket(%s)!\n", input.Key, input.Bucket) if obsError, ok := err.(obs.ObsError); ok { fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.") fmt.Println(obsError.Error()) } else { fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.") fmt.Println(err) } } |
