Listing Parallel File Systems (SDK for Go)
Function
Parallel file systems (PFSs) are containers for storing objects in OBS. Files uploaded to OBS are stored as objects in PFSs. This API returns a list of all PFSs that meet the specified conditions in all regions of the current account. Returned PFSs are listed in alphabetical order by PFS name.
Restrictions
- To list PFSs, you must have the obs:bucket:ListAllMyBuckets permission. IAM is recommended for granting permissions. For details, see IAM Custom Policies.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
func (obsClient ObsClient) ListBuckets(input *ListBucketsInput) (output *ListBucketsOutput, err error)
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| input | No | Explanation: Input parameters for listing PFSs. For details, see Table 2. |
| QueryLocation | bool | No | Explanation: Whether to query the PFS location. Value range:
Default value: false |
| BucketType | No | Explanation: Type of the buckets to be listed. Value range: See Table 3. Default value: If this parameter is not specified, all buckets and parallel file systems are listed. |
Responses
| Parameter | Type | Description |
| output | Explanation: Returned results. For details, see Table 5. | |
| err | error | Explanation: Error messages returned by the API |
| StatusCode | int | Explanation: HTTP status code Value range: A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
| RequestId | string | Explanation: Request ID returned by the OBS server Default value: None |
| ResponseHeaders | map[string][]string | Explanation: HTTP response headers Default value: None |
| Owner | Explanation: PFS owner. Value range: See Table 6. | |
| Buckets | []Bucket | Explanation: PFS list. Value range: See Table 7. |
| ID | string | Yes if used as a request parameter | Explanation: Account (domain) ID of the owner Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
| Name | string | Explanation: Bucket name Restrictions:
| CreationDate | time.Time | Explanation: Time when the bucket was created Default value: None |
| Location | string | Explanation: Region where a bucket is located Restrictions: If the used endpoint is obs.myhuaweicloud.com, this parameter is not required. If any other endpoint is used, this parameter is required. Value range: To learn about valid regions and endpoints, see Regions and Endpoints. An endpoint is the request address for calling an API. Endpoints vary depending on services and regions. To obtain the regions and endpoints, contact the enterprise administrator. Default value: If obs.myhuaweicloud.com is used as the endpoint and no region is specified, cn-north-1 (the CN North-Beijing1 region) is used by default. |
| BucketType | string | Explanation: Bucket type Value range:
Code Examples
This example lists all PFSs.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 | package main import ( "fmt" "os" obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs" ) func main() { //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html. ak := os.Getenv("AccessKeyID") sk := os.Getenv("SecretAccessKey") // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // securityToken := os.Getenv("SecurityToken") // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here as an example. Replace it with the one currently in use. endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com" // Create an obsClient instance. // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance. obsClient, err := obs.New(ak, sk, endPoint/*, obs.WithSecurityToken(securityToken)*/) if err != nil { fmt.Printf("Create obsClient error, errMsg: %s", err.Error()) } input := &obs.ListBucketsInput{} // Specify whether to query the PFS location in the listing. The default value is false. true is used as an example. input.QueryLocation = true // Specify the type of the buckets to list. By default, all buckets and PFSs are listed. obs.POSIX is used as an example, indicating that all PFSs are listed. input.BucketType = obs.POSIX // List PFSs. output, err := obsClient.ListBuckets(input) if err == nil { fmt.Printf("List buckets successful!\n") fmt.Printf("RequestId:%s\n", output.RequestId) for index, val := range output.Buckets { fmt.Printf("Bucket[%d]-Name:%s,CreationDate:%s\n", index, val.Name, val.CreationDate) } return } fmt.Printf("List buckets fail!\n") if obsError, ok := err.(obs.ObsError); ok { fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.") fmt.Println(obsError.Error()) } else { fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.") fmt.Println(err) } } |
