Deleting the BPA Configuration of a Bucket (SDK for Go)
Function
This API deletes the public access block configuration of an OBS bucket.
Restrictions
- To delete the BPA configuration of a bucket, you must be the bucket owner or have the required permission (obs:bucket:DeleteBucketPublicAccessBlock in IAM or DeleteBucketPublicAccessBlock in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
func (obsClient ObsClient) DeleteBucketPublicAccessBlock(input *DeleteBucketPublicAccessBlockInput) (output *BaseModel, err error)
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| input | Yes | Explanation: Request parameters for deleting the BPA configuration of a bucket. For details, see DeleteBucketPublicAccessBlockInput. |
| bucketName | String | Yes | Explanation: Bucket name. Restrictions:
Default value: None |
Responses
| Parameter | Type | Description |
| output | Explanation: Returned results. For details, see Table 4. | |
| err | error | Explanation: Error messages returned by the API |
| StatusCode | int | Explanation: HTTP status code Value range: A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
| RequestId | string | Explanation: Request ID returned by the OBS server Default value: None |
| ResponseHeaders | map[string][]string | Explanation: HTTP response headers Default value: None |
Code Examples
This example deletes the PublicAccessBlock configuration of bucket examplebucket.
package main
import (
"fmt"
"os"
obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs"
func main() {
//Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
//Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
ak := os.Getenv("AccessKeyID")
sk := os.Getenv("SecretAccessKey")
// (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
securityToken := os.Getenv("SecurityToken")
// Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com"
// Create an obsClient instance.
// If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance.
obsClient, err := obs.New(ak, sk, endPoint, obs.WithSecurityToken(securityToken))
if err != nil {
fmt.Printf("Create obsClient error, errMsg: %s", err.Error())
// Specify the bucket name.
bucketName := "examplebucket"
// Delete the PublicAccessBlock configuration of the bucket.
output, err := obsClient.DeleteBucketPublicAccessBlock(bucketName)
if err == nil {
fmt.Printf("Delete bucket(%s)'s PublicAccessBlock successful!\n", bucketName)
fmt.Printf("RequestId:%s\n", output.RequestId)
return
fmt.Printf("Delete bucket(%s)'s PublicAccessBlock fail!\n", bucketName)
if obsError, ok := err.(obs.ObsError); ok {
fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.")
fmt.Println(obsError.Error())
} else {
fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.")
fmt.Println(err)
} Feedback
