Why Does the SDK Source Code Contain acs.amazonaws.com?
To be compatible with AWS S3, the OBS SDK source code contains acs.amazonaws.com as a fixed format.
The SDK neither processes nor accesses this keyword and only takes it as a constant.
You can ignore this keyword. The figure below gives an example. For details, see SDK for Go.
