How Do I Specify Content-SHA256?
You can upload the x-obs-content-sha256 header when uploading an object or a part. The value of this header is the hexadecimal value converted from the SHA256 value of the request body and is calculated from Hex(SHA256Hash(<payload>). The server calculates and verifies the SHA256 value of the message body in the request with x-obs-content-sha256 included, which may make performance deteriorate, but is recommended for security purposes. Sample code is as follows:
This example deletes the asynchronous fetch policy of bucket examplebucket.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 | package main import ( "crypto/sha256" "fmt" "io" "os" obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs" ) func sha256File(path string) string { file, err := os.Open(path) // Open the file for reading if err != nil { panic(err) } defer file.Close() // Be sure to close your file! hash := sha256.New() // Use the Hash in crypto/sha256 if _, err := io.Copy(hash, file); err != nil { panic(err) } return fmt.Sprintf("%x", hash.Sum(nil)) } func main() { //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html. ak := os.Getenv("AccessKeyID") sk := os.Getenv("SecretAccessKey") // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. securityToken := os.Getenv("SecurityToken") // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com" // Create an obsClient instance. // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance. obsClient, err := obs.New(ak, sk, endPoint, obs.WithSecurityToken(securityToken), obs.WithSignature(obs.SignatureObs)) if err != nil { fmt.Printf("Create obsClient error, errMsg: %s", err.Error()) } input := &obs.PutObjectInput{} // Specify a bucket name. input.Bucket = "examplebucket" // Specify the object (example/objectname as an example) to download. input.Key = "example/objectname" filePath := "localfile" fd, _ := os.Open(filePath) defer fd.Close() input.Body = fd // Upload you local file using streaming. output, err := obsClient.PutObject(input, obs.WithCustomHeader("x-obs-content-sha256", sha256File(filePath))) if err == nil { fmt.Printf("Put object(%s) under the bucket(%s) successful!\n", input.Key, input.Bucket) fmt.Printf("StorageClass:%s, ETag:%s\n", output.StorageClass, output.ETag) return } fmt.Printf("Put object(%s) under the bucket(%s) fail!\n", input.Key, input.Bucket) if obsError, ok := err.(obs.ObsError); ok { fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.") fmt.Println(obsError.Error()) } else { fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.") fmt.Println(err) } } |
OBS SDK for Go supports integrity check with both MD5 and SHA256 (SHA256 is recommended for security purposes).
