Updated on 2026-07-21 GMT+08:00
Viewing Bucket Logging
If you have any questions during the development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
You can call ObsClient.GetBucketLogging to view the logging configuration of a bucket.
This example views the logging configuration of bucket bucketname.
The sample code is as follows:
// Initialize configuration parameters.
ObsConfig config = new ObsConfig();
config.Endpoint = "https://your-endpoint";
// Hard-coded or plaintext AK and SK are risky. For security purposes, encrypt your AK and SK before storing them in the configuration file or environment variables. In this example, the AK and SK are stored in environment variables. Before running the code in this example, configure environment variables AccessKeyID and SecretAccessKey.
// Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
string accessKey= Environment.GetEnvironmentVariable("AccessKeyID", EnvironmentVariableTarget.Machine);
string secretKey= Environment.GetEnvironmentVariable("SecretAccessKey", EnvironmentVariableTarget.Machine);
// Create an instance of ObsClient.
ObsClient client = new ObsClient(accessKey, secretKey, config);
// View bucket logging.
try
    GetBucketLoggingRequest request = new GetBucketLoggingRequest
        BucketName = "bucketname",
    GetBucketLoggingResponse response = client.GetBucketLogging(request);
    Console.WriteLine("TargetBucketName is : " + response.Configuration.TargetBucketName);
    Console.WriteLine("TargetPrefix is : " + response.Configuration.TargetPrefix);
    Console.WriteLine("Get bucket logging response: {0}", response.StatusCode);
catch (ObsException ex)
    Console.WriteLine("ErrorCode: {0}", ex.ErrorCode);
    Console.WriteLine("ErrorMessage: {0}", ex.ErrorMessage);
To handle the error codes possibly returned during the operation, see SDK Error Codes.
