Listing Versioning Objects
Updated on 2024-05-08 GMT+08:00
NOTICE:
If you have any questions during the development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
You can call ObsClient.ListVersions to list versioning objects.
The following table describes the parameters involved in this API.
Property in OBS .NET SDK
BucketName
Bucket name
ListVersionsRequest.BucketName
Prefix
Name prefix that the objects to be listed must contain
ListVersionsRequest.Prefix
KeyMarker
Object name to start with when listing versioning objects in a bucket. All versioning objects following this parameter are listed in the lexicographical order.
ListVersionsRequest.KeyMarker
MaxKeys
Maximum number of listed versioning objects. The value ranges from 1 to 1000. If the specified value exceeds 1000, only 1,000 versioning objects are returned by default.
ListVersionsRequest.MaxKeys
Delimiter
Character used to group object names. If the object name contains the Delimiter parameter, the character string from the first character to the first delimiter in the object name is grouped under a single result element, CommonPrefix. (If a prefix is specified in the request, the prefix must be removed from the object name.)
ListVersionsRequest.Delimiter
VersionIdMarker
Object name to start with when listing versioning objects in a bucket. All versioning objects are listed in the lexicographical order by object name and version ID. This parameter must be used together with KeyMarker.
ListVersionsRequest.VersionIdMarker
  • If the value of VersionIdMarker is not a version ID specified by KeyMarker, VersionIdMarker is ineffective.
  • The returned result of ObsClient.ListVersions includes the versioning objects and delete markers.
Listing Versioning Objects in Simple Mode
The following sample code shows how to list versioning objects in simple mode. A maximum of 1000 versioning objects can be returned.
// Initialize configuration parameters.
ObsConfig config = new ObsConfig();
config.Endpoint = "https://your-endpoint";
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey.
// Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
string accessKey= Environment.GetEnvironmentVariable("AccessKeyID", EnvironmentVariableTarget.Machine);
string secretKey= Environment.GetEnvironmentVariable("SecretAccessKey", EnvironmentVariableTarget.Machine);
// Create an instance of ObsClient.
ObsClient client = new ObsClient(accessKey, secretKey, config);
//List versioning objects.
try
    ListVersionsRequest request = new ListVersionsRequest();
    request.BucketName = "bucketname";
    ListVersionsResponse response = client.ListVersions(request);
    foreach (ObsObjectVersion objectVersion in response.Versions)
        Console.WriteLine("Key: {0}", objectVersion.ObjectKey);
        Console.WriteLine("VersionId: {0}", objectVersion.VersionId);
    Console.WriteLine("List versions response: {0}", response.StatusCode);
catch (ObsException ex)
    Console.WriteLine("ErrorCode: {0}", ex.ErrorCode);
    Console.WriteLine("ErrorMessage: {0}", ex.ErrorMessage);
Information about a maximum of 1000 versioning objects can be listed each time. If a bucket contains more than 1000 objects and ListVersionsResponse.IsTruncated is true in the returned result, not all versioning objects are listed. In such cases, you can use ListVersionsResponse.NextKeyMarker and ListVersionsResponse.NextVersionIdMarker to obtain the start position for next listing.
Listing Versioning Objects by Specifying the Number
Sample code:
//List versioning objects by specifying the number.
try
    request.MaxKeys = 100;
Listing Versioning Objects by Specifying a Prefix
Sample code:
//List versioning objects by specifying a prefix.
try
    request.Prefix = "prefix";
Listing Versioning Objects by Specifying the Start Position
Sample code:
//Specify the start position for listing.
try
    request.KeyMarker = "keyMarker";
Listing All Versioning Objects in Paging Mode
Sample code:
//List all versioning objects in paging mode.
try
    ListVersionsResponse response;
    do
        request.KeyMarker = response.NextKeyMarker;
        request.VersionIdMarker = response.NextVersionIdMarker;
    while (response.IsTruncated);
Listing All Versioning Objects in a Folder
There is no folder concept in OBS. All elements in buckets are objects. Folders are actually objects whose sizes are 0 and whose names end with a slash (/). When you set a folder name as the prefix, objects in this folder will be listed. Sample code is as follows:
try
    request.MaxKeys = 1000;
    // Set the prefix to dir/.
    request.Prefix = "dir/";
    do
