Listing Objects
If you have any questions during the development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
You can call ObsClient.ListObjects to list objects in a bucket.
The following table describes the parameters involved in this API.
| Parameter | Description | Property in OBS .NET SDK |
| BucketName | Bucket name | ListObjectsRequest.BucketName |
| Prefix | Name prefix that the objects to be listed must contain | ListObjectsRequest.Prefix |
| Marker | Object name to start with when listing objects. All objects whose names follow the specified value lexicographically are returned. | ListObjectsRequest.Marker |
| MaxKeys | Maximum number of objects listed in the response body. The value ranges from 1 to 1000. If the value exceeds 1000, only 1,000 objects are returned. | ListObjectsRequest.MaxKeys |
| Delimiter | Character used to group object names. If the object name contains the Delimiter parameter, the character string from the first character to the first delimiter in the object name is grouped under a single result element, CommonPrefix. (If a prefix is specified in the request, the prefix must be removed from the object name.) For a parallel file system, if this parameter is not specified, all the content in the directory is recursively listed by default, and subdirectories are also listed. In big data scenarios, parallel file systems usually have deep directory levels and each directory has a large number of files. In such case, you are advised to configure [delimiter="/"] to list the content in the current directory, but not list subdirectories, thereby improving the listing efficiency. | ListObjectsRequest.Delimiter |
Listing Objects in Simple Mode
The following sample code shows how to list objects in simple mode. A maximum of 1,000 objects can be returned.
// Initialize configuration parameters.
ObsConfig config = new ObsConfig();
config.Endpoint = "https://your-endpoint";
// Hard-coded or plaintext AK and SK are risky. For security purposes, encrypt your AK and SK before storing them in the configuration file or environment variables. In this example, the AK and SK are stored in environment variables. Before running the code in this example, configure environment variables AccessKeyID and SecretAccessKey.
// Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
string accessKey= Environment.GetEnvironmentVariable("AccessKeyID", EnvironmentVariableTarget.Machine);
string secretKey= Environment.GetEnvironmentVariable("SecretAccessKey", EnvironmentVariableTarget.Machine);
// Create an instance of ObsClient.
ObsClient client = new ObsClient(accessKey, secretKey, config);
// Simple listing
try
ListObjectsRequest request = new ListObjectsRequest();
request.BucketName = "bucketname";
ListObjectsResponse response = client.ListObjects(request);
foreach (ObsObject entry in response.ObsObjects)
Console.WriteLine("key = {0} size = {1}", entry.ObjectKey, entry.Size);
catch (ObsException ex)
Console.WriteLine("ErrorCode: {0}", ex.ErrorCode);
Console.WriteLine("ErrorMessage: {0}", ex.ErrorMessage);
Information about a maximum of 1000 objects can be listed each time. If a bucket contains more than 1000 objects and ListObjectsResponse.IsTruncated is true in the returned result, not all objects are listed. In such cases, you can use ListObjectsResponse.NextMarker to obtain the start position for next listing.
Listing Objects by Specifying the Number
The sample code is as follows:
// Specify the number.
try
// Set the number of objects to be listed to 100.
request.MaxKeys = 100;
} Listing Objects by Specifying a Prefix
// List objects by specifying a prefix.
try
//Specify the prefix.
request.Prefix = "prefix";
} Listing Objects by Specifying the Start Position
// List objects by specifying the start position.
try
//Specify the start position for listing.
request.Marker = "marker";
} Listing All Objects in Paging Mode
//List all objects in paging mode.
try
ListObjectsResponse response;
do
request.Marker = response.NextMarker;
while (response.IsTruncated);
} Listing All Objects in a Folder
There is no folder concept in OBS. All elements in buckets are objects. Folders are actually objects whose sizes are 0 and whose names end with a slash (/). When you set a folder name as the prefix, objects in this folder will be listed. The sample code is as follows:
//List all objects in a folder.
try
request.MaxKeys = 1000;
// Set the prefix to dir/.
request.Prefix = "dir/";
do
} Feedback
