Help Center/
Object Storage Service/
SDK Reference/
C/
Static Website Hosting (SDK for C)/
Hosting Website Files in a Bucket (SDK for C)
If you have any questions during development, post them on the Issues page of GitHub.
You can perform the following to implement website file hosting:
- Upload a website file to your bucket in OBS as an object and set the MIME type for the object.
- Set the object ACL to public read.
- Access the object using a browser.
Code Examples: Website File Hosting
This example implements website file hosting.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 |
#include "eSDKOBS.h" #include <stdio.h> #include <sys/stat.h> // The response callback function. The content of properties in the callback can be recorded in callback_data (custom callback data). obs_status response_properties_callback(const obs_response_properties *properties, void *callback_data); int put_file_data_callback(int buffer_size, char *buffer, void *callback_data); void put_file_complete_callback(obs_status status, const obs_error_details *error, void *callback_data); typedef struct put_file_object_callback_data { FILE *infile; uint64_t content_length; obs_status ret_status; } put_file_object_callback_data; uint64_t open_file_and_get_length(char *localfile, put_file_object_callback_data *data); int main() { // The following code shows how to implement website file hosting: // Call the obs_initialize method at the program entry to initialize global resources such as the network and memory. obs_initialize(OBS_INIT_ALL); obs_options options; // Create and initialize options, including the access domain name (host_name), access keys (access_key_id and access_key_secret), bucket name (bucket_name), and bucket storage class (storage_class). init_obs_options(&options); // Enter the endpoint corresponding to the bucket for host_name. CN-Hong Kong is used here as an example. Replace it with the one in your actual situation. options.bucket_options.host_name = "obs.ap-southeast-1.myhuaweicloud.com"; // Hard-coded or plaintext AK and SK are risky. For security purposes, encrypt your AK and SK and store them in the configuration file or environment variables. // In this example, the AK and SK are stored in environment variables for identity authentication. Before running the code in this example, configure local environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY. options.bucket_options.access_key = getenv("ACCESS_KEY_ID"); options.bucket_options.secret_access_key = getenv("SECRET_ACCESS_KEY"); // Specify the bucket name, for example, example-bucket-name. char * bucketName = "example-bucket-name"; options.bucket_options.bucket_name = bucketName; // Initialize the properties of the object to be uploaded. obs_put_properties put_properties; init_put_properties(&put_properties); // Name of the object to be uploaded char *key = "example_put_file_html_test.html"; // Uploaded file char file_name[256] = "./example_local_file_test.html"; // Set the MIME type. put_properties.content_type = "text/html"; // Set the object ACL to public read. put_properties.canned_acl = OBS_CANNED_ACL_PUBLIC_READ; put_properties.content_disposition_filename = ""; uint64_t content_length = 0; // Initialize the structure for storing the uploaded data. put_file_object_callback_data data; memset(&data, 0, sizeof(put_file_object_callback_data)); // Open the file and obtain the file length. content_length = open_file_and_get_length(file_name, &data); // Set the callback function. obs_put_object_handler putobjectHandler = { { &response_properties_callback, &put_file_complete_callback }, &put_file_data_callback }; put_object(&options, key, content_length, &put_properties, 0, &putobjectHandler, &data); if (OBS_STATUS_OK == data.ret_status) { printf("put object from file successfully. \n"); } else { printf("put object failed(%s).\n", obs_get_status_name(data.ret_status)); } if (data.infile != NULL) { fclose(data.infile); } // Release the allocated global resources. obs_deinitialize(); } // The response callback function. The content of properties in the callback can be recorded in callback_data (custom callback data). obs_status response_properties_callback(const obs_response_properties *properties, void *callback_data) { if (properties == NULL) { printf("error! obs_response_properties is null!"); if (callback_data != NULL) { obs_sever_callback_data *data = (obs_sever_callback_data *)callback_data; printf("server_callback buf is %s, len is %llu", data->buffer, data->buffer_len); return OBS_STATUS_OK; } else { printf("error! obs_sever_callback_data is null!"); return OBS_STATUS_OK; } } // Print the response. #define print_nonnull(name, field) \ do { \ if (properties-> field) { \ printf("%s: %s\n", name, properties->field); \ } \ } while (0) print_nonnull("request_id", request_id); print_nonnull("request_id2", request_id2); print_nonnull("content_type", content_type); if (properties->content_length) { printf("content_length: %llu\n", properties->content_length); } print_nonnull("server", server); print_nonnull("ETag", etag); print_nonnull("expiration", expiration); print_nonnull("website_redirect_location", website_redirect_location); print_nonnull("version_id", version_id); print_nonnull("allow_origin", allow_origin); print_nonnull("allow_headers", allow_headers); print_nonnull("max_age", max_age); print_nonnull("allow_methods", allow_methods); print_nonnull("expose_headers", expose_headers); print_nonnull("storage_class", storage_class); print_nonnull("server_side_encryption", server_side_encryption); print_nonnull("kms_key_id", kms_key_id); print_nonnull("customer_algorithm", customer_algorithm); print_nonnull("customer_key_md5", customer_key_md5); print_nonnull("bucket_location", bucket_location); print_nonnull("obs_version", obs_version); print_nonnull("restore", restore); print_nonnull("obs_object_type", obs_object_type); print_nonnull("obs_next_append_position", obs_next_append_position); print_nonnull("obs_head_epid", obs_head_epid); print_nonnull("reserved_indicator", reserved_indicator); int i; for (i = 0; i < properties->meta_data_count; i++) { printf("x-obs-meta-%s: %s\n", properties->meta_data[i].name, properties->meta_data[i].value); } return OBS_STATUS_OK; } int put_file_data_callback(int buffer_size, char *buffer, void *callback_data) { put_file_object_callback_data *data = (put_file_object_callback_data *)callback_data; int ret = 0; if (data->content_length) { int toRead = ((data->content_length > (unsigned)buffer_size) ? (unsigned)buffer_size : data->content_length); ret = fread(buffer, 1, toRead, data->infile); } uint64_t originalContentLength = data->content_length; data->content_length -= ret; if (data->content_length) { printf("%llu bytes remaining ", (unsigned long long)data->content_length); printf("(%d%% complete) ...\n", (int)(((originalContentLength - data->content_length) * 100) / originalContentLength)); } return ret; } void put_file_complete_callback(obs_status status, const obs_error_details *error, void *callback_data) { put_file_object_callback_data *data = (put_file_object_callback_data *)callback_data; data->ret_status = status; } uint64_t open_file_and_get_length(char *localfile, put_file_object_callback_data *data) { uint64_t content_length = 0; const char *body = 0; if (!content_length) { struct stat statbuf; if (stat(localfile, &statbuf) == -1) { fprintf(stderr, "\nERROR: Failed to stat file %s: ", localfile); return 0; } content_length = statbuf.st_size; } if (!(data->infile = fopen(localfile, "rb"))) { fprintf(stderr, "\nERROR: Failed to open input file %s: ", localfile); return 0; } data->content_length = content_length; return content_length; } |
Parent topic: Static Website Hosting (SDK for C)
