Downloading an Object - Conditional (SDK for C)
  If you have any questions during development, post them on the Issues page of GitHub.
Function
This API returns the objects that meet one or more conditions. If there are no objects that meet the specified conditions, an error is returned.
Restrictions
- To download an object, you must be the bucket owner or have the required permission (obs:object:GetObject in IAM or GetObject in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
 - The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
 - Objects in the Archive storage class can be downloaded only when they are in the Restored status.
Method
void get_object(const obs_options *options, obs_object_info *object_info,
    obs_get_conditions *get_conditions,
    server_side_encryption_params *encryption_params,
    obs_get_object_handler *handler, void *callback_data);
 Request Parameters
        Parameter  |
        Type  |
        Mandatory (Yes/No)  |
        Description  |
        options  |
        const obs_options*  |
        Yes  |
        Explanation: The context of the requested bucket. Refer to Configuring option (SDK for C) to set the AK, SK, endpoint, bucket, timeout, and temporary credentials through obs_options. Restrictions: None  |
        object_info  |
        Yes  |
        Explanation: Object name and version ID. Restrictions: For a non-versioned object, set the version ID to 0.  |
        get_conditions  |
        Yes  |
        Explanation: Sets filter conditions of the object and read range. Restrictions: None  |
        encryption_params  |
        No  |
        Explanation: Obtains the decryption settings of an object. Restrictions: None  |
        handler  |
        Yes  |
        Explanation: A callback structure where all members are pointers to callback functions, used to set the callback functions that handle response data. You can set a callback function to copy the response data from the server to your custom callback_data. Restrictions: None  |
        callback_data  |
        void *  |
        No  |
        Explanation: Custom callback data. Restrictions: None Value range: None Default value: None  |
        Parameter  |
        Type  |
        Description  |
        bucket_options  |
        Yes  |
        Explanation: Bucket settings. Restrictions: None  |
        request_options  |
        Yes  |
        Explanation: Request-related settings. Restrictions: None  |
        temp_auth  |
        No  |
        Explanation: The structure used to calculate a temporary signature. Set it to NULL if it is not used. Restrictions: None  |
        Parameter  |
        Type  |
        Description  |
        host_name  |
        char *  |
        Yes  |
        Explanation: The requested host name, used as an address for connecting to OBS. It is the domain name (the endpoint) of the server where the requested resource is stored. Example: host_name = "obs.ap-southeast-1.myhuaweicloud.com"; Restrictions: The value does not need to contain http:// or https:// as a prefix, which is controlled using obs_protocol. Value range: To view the endpoints available for OBS, see Regions and Endpoints. Default value: None  |
        bucket_name  |
        char *  |
        Yes  |
        Explanation: Bucket name. Restrictions:
        useCname  |
        bool  |
        No  |
        Explanation: Whether to use a custom domain name to access OBS. Restrictions: None Value range: true: A custom domain name is used. false: A custom domain name is not used. Default value: false  |
        protocol  |
        No  |
        Explanation: Whether to use the HTTP or HTTPS protocol. Restrictions: None Value range: For details, see obs_protocol. Default value: OBS_PROTOCOL_HTTPS (HTTPS is used by default.)  |
        access_key  |
        char *  |
        Yes  |
        Explanation: Access key ID (AK). Restrictions: None Value range: For details, see Creating Access Keys. Default value: None  |
        secret_access_key  |
        char *  |
        Yes  |
        Explanation: Secret access key (SK). Restrictions: None Value range: For details, see Creating Access Keys. Default value: None  |
        storage_class  |
        No  |
        Explanation: Bucket storage class that can be specified at bucket creation. Restrictions: None Value range: For details, see obs_storage_class. Default value: OBS_STORAGE_CLASS_STANDARD (Standard storage class)  |
        token  |
        char *  |
        No  |
        Explanation: The security token in temporary credentials. Restrictions: None Value range: For details, see Creating Access Keys. Default value: None  |
        epid  |
        char *  |
        No  |
        Explanation: Enterprise project ID that can be specified during bucket creation. If you have enabled EPS, you can obtain the project ID from the EPS console. Restrictions: The value needs to be represented as a UUID. This parameter is not required if EPS is not enabled. Example: 9892d768-2d13-450f-aac7-ed0e44c2585f Default value: None  |
        bucket_type  |
        No  |
        Explanation: Whether a bucket is an object bucket or a parallel file system. Restrictions: None Value range: For details, see obs_bucket_type. Default value: OBS_BUCKET_OBJECT (object bucket)  |
        bucket_list_type  |
        No  |
        Explanation: Whether to list all buckets, object buckets, or parallel file systems. Restrictions: None Value range: For details, see obs_bucket_list_type.  |
        Value  |
        Description  |
        OBS_STORAGE_CLASS_STANDARD  |
        Standard storage class. This class features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response.  |
        OBS_STORAGE_CLASS_STANDARD_IA  |
        Infrequent Access storage class. Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but becomes instantly available when needed.  |
        OBS_STORAGE_CLASS_GLACIER  |
        Archive storage class. Used for storing rarely accessed (once a year) data.  |
        Parameter  |
        Type  |
        Description  |
        connect_time  |
        int  |
        Yes  |
        Explanation: Timeout period for establishing an HTTP/HTTPS connection, in ms. Restrictions: None Value range: [10000, 60000] Default value: 60000  |
        max_connected_time  |
        int  |
        Yes  |
        Explanation: Timeout period (in seconds) of a request. Restrictions: None Value range: None Default value: 0 (There is never automatic disconnection.)  |
        proxy_auth  |
        char*  |
        No  |
        Explanation: Proxy authentication information, in the format username:password Restrictions: None Value range: None Default value: None  |
        proxy_host  |
        char*  |
        No  |
        Explanation: IP address or host name of the proxy server. Restrictions: None Value range: None Default value: None  |
        Value  |
        Description  |
        OBS_PROTOCOL_HTTPS  |
        HTTPS is used for access.  |
        OBS_PROTOCOL_HTTP  |
        HTTP is used for access.  |
        Value  |
        Description  |
        OBS_BUCKET_OBJECT  |
        Object bucket  |
        OBS_BUCKET_PFS  |
        Parallel file system  |
        Value  |
        Description  |
        OBS_BUCKET_LIST_ALL  |
        Lists all buckets.  |
        OBS_BUCKET_LIST_OBJECT  |
        Lists all object buckets.  |
        OBS_BUCKET_LIST_PFS  |
        Lists all parallel file systems.  |
        Parameter  |
        Type  |
        Description  |
        expires  |
        long long int  |
        Yes  |
        Explanation: Validity period of the temporary credentials, in seconds. Restrictions: None Value range: [0-630720000] Default value: None  |
        temp_auth_callback  |
        void(*temp_auth_callback)(char *temp_auth_url, uint64_t temp_auth_url_len, char*temp_auth_headers, uint64_t temp_auth_headers_len, void*callback_data)  |
        Yes  |
        Explanation: The pointer to the custom callback function, which is used to record the temporary URL and involved signature header to the custom callback data. Restrictions: None  |
        callback_data  |
        void *  |
        Yes  |
        Parameter  |
        Type  |
        Description  |
        temp_auth_url  |
        char *  |
        Yes  |
        Explanation: Temporary URL. OBS allows you to construct a URL for a specific operation. In such a URL, you use Query parameters to provide authentication information including the user AK, signature, and validity period. Anyone who has the URL can perform the specified operation. After receiving a request made using such a URL, OBS treats the requester as the user who issued the URL and processes the request. For example, if you construct a pre-signed URL for downloading an object and provide it to various users, they can use the URL to download the object without authentication, but they must do so within the validity period specified by the Expires parameter. Restrictions: None Value range: None Default value: None  |
        temp_auth_url_len  |
        uint64_t  |
        Yes  |
        Explanation: Length of the temporary URL. Restrictions: None Value range: None Default value: None  |
        temp_auth_headers  |
        char *  |
        Yes  |
        Explanation: Headers for temporary authentication. Restrictions: None Value range: None Default value: None  |
        temp_auth_headers_len  |
        uint64_t  |
        Yes  |
        Explanation: Number of temporary authentication headers. Restrictions: None Value range: None Default value: None  |
        callback_data  |
        void *  |
        Yes  |
        Parameter  |
        Type  |
        Description  |
        response_handler  |
        Yes  |
        Explanation: Response callback function structure. Restrictions: None  |
        get_object_data_callback  |
        Yes  |
        Explanation: Pointer to the callback function, which is used to copy the data to be downloaded from the data buffer to the custom callback data. Restrictions: None  |
        Parameter  |
        Type  |
        Description  |
        properties_callback  |
        Yes  |
        Explanation: The pointer to the response callback function. The content of properties in the callback can be recorded in callback_data (custom callback data). Restrictions: None  |
        complete_callback  |
        Yes  |
        Explanation: The pointer to the completion callback function. The content of obs_status and obs_error_details in the callback can be recorded in callback_data (custom callback data). Restrictions: None  |
        Parameter  |
        Type  |
        Description  |
        properties  |
        const obs_response_properties*  |
        Yes  |
        Explanation: Parameters in the response headers. You are advised to record them to callback_data (custom callback data). Restrictions: None  |
        callback_data  |
        void *  |
        Yes  |
        Explanation: The pointer to the custom callback data. Restrictions: None Value range: None Default value: None  |
        Parameter  |
        Type  |
        Description  |
        status  |
        Yes  |
        Explanation: Internal request status code of the SDK. Restrictions: None Value range: For details, see obs_status.  |
        error_details  |
        const obs_error_details*  |
        Yes  |
        callback_data  |
        void *  |
        Yes  |
        Parameter  |
        Type  |
        Description  |
        request_id  |
        const char *  |
        No  |
        Explanation: The value created by OBS to uniquely identify the request. OBS uses this value to locate the fault. Restrictions: None Value range: None Default value: None  |
        request_id2  |
        const char *  |
        No  |
        Explanation: A special symbol that helps troubleshoot. Restrictions: None Value range: None Default value: None  |
        content_type  |
        const char *  |
        No  |
        Explanation: MIME type of the object. MIME type is a standard way of describing a data type and is used by the browser to decide how to display data. Restrictions: None Value range: None Default value: None  |
        content_length  |
        uint64_t  |
        No  |
        Explanation: The size (in bytes) of the response body. Restrictions: None Value range: None Default value: None  |
        server  |
        const char *  |
        No  |
        Explanation: Server header in an HTTP request. Restrictions: None Value range: None Default value: None  |
        etag  |
        const char *  |
        No  |
        Explanation: Base64-encoded, 128-bit MD5 value of an object. It uniquely identifies the content of an object and can be used to check the object integrity. For example, if the ETag is A when an object is uploaded and is B when the object is downloaded, it indicates that the object content has been changed. The ETag reflects changes to the contents of the object, not its metadata. An object created by an upload or copy operation has a unique ETag. Restrictions: If an object is encrypted using server-side encryption, the ETag is not the MD5 value of the object. Value range: The value must contain 32 characters. Default value: None  |
        expiration  |
        const char *  |
        No  |
        Explanation: Expiration details of the object. Restrictions: None Value range: An integer greater than 0, in days. Default value: None  |
        website_redirect_location  |
        const char *  |
        No  |
        Explanation: Indicates where an object request is redirected. If the bucket that contains the object is configured with Website settings, this parameter can be set in the object metadata so that the request for the object can be redirected to another object in the same bucket or an external URL after the website returns a 301 redirect response. To another object in the same bucket: x-obs-website-redirect-location:/anotherPage.html To an external URL: x-obs-website-redirect-location:http://www.example.com/ OBS obtains the specified value from the header and stores it in the object metadata WebsiteRedirectLocation. Restrictions:
        version_id  |
        const char *  |
        No  |
        Explanation: Object version ID. Restrictions: If the object has no version ID, the value is NULL. Value range: The value must contain 32 characters. Default value: None  |
        meta_data_count  |
        int  |
        No  |
        Explanation: Number of elements in the meta_data array. Restrictions: None Value range: None Default value: None  |
        meta_data  |
        const obs_name_value *  |
        No  |
        Explanation: Custom metadata of the object. You can add custom metadata headers that start with x-obs-meta- for easy object management. When you retrieve or query the metadata of the object, the added custom metadata headers will be returned in the response. Restrictions: None  |
        use_server_side_encryption  |
        char  |
        No  |
        Explanation: If server-side encryption is enabled, this parameter is set to '\1'. Restrictions: None Value range: None Default value: None  |
        allow_origin  |
        const char *  |
        No  |
        Explanation: Returned if the request origin meets the CORS configured on the server. Restrictions: None Value range: The value that complies with the CORS Default value: None  |
        allow_headers  |
        const char *  |
        No  |
        Explanation: Returned if the request headers meet the CORS configured on the server. Restrictions: At most one asterisk (*) is allowed. Spaces, ampersands (&), colons (:), less-than signs (<), and full-width characters are not allowed. Value range: The value that complies with the CORS Default value: None  |
        max_age  |
        const char *  |
        No  |
        Explanation: MaxAgeSeconds in the CORS rules of the bucket. It specifies the time your client can cache the response for a cross-origin request. Restrictions: Each CORS rule can contain at most one MaxAgeSeconds. Value range: An integer greater than or equal to 0, in seconds. Default value: 3000  |
        allow_methods  |
        const char *  |
        No  |
        Explanation: Indicates that methods in the rule are included in the response if Access-Control-Request-Method in the request meets the CORS configuration requirements when CORS is configured for buckets. Restrictions: None Value range:
 Value range: None  |
        expose_headers  |
        const char *  |
        No  |
        Explanation: ExposeHeader in the CORS rules of the bucket. It specifies additional headers allowed in the response by a CORS rule. These headers provide extra information to clients. By default, a browser can access only headers Content-Length and Content-Type. If the browser needs to access other headers, you need to configure them as additional headers. Restrictions: Spaces, asterisks (*), ampersands (&), colons (:), less-than signs (<), and full-width characters are not allowed. Value range: None Default value: None  |
        storage_class  |
        const char *  |
        No  |
        Explanation: Object storage class. Restrictions: This header is returned only when the storage class of an object is not Standard. Value range:
        const char *  |
        No  |
        Explanation: The encryption method used by the server. Example: x-obs-server-side-encryption:kms Restrictions: This header is included in a response if SSE-KMS is used. Value range:
        kms_key_id  |
        const char *  |
        No  |
        Explanation: Key ID. If the SSE-KMS encryption is used with a specified key, the key ID is required. Restrictions: This header can only be used when you specify kms for the server_side_encryption header. Value range: To obtain the key ID, see Viewing a CMK. Default value: If you specify kms for encryption but do not specify a key ID, the default master key will be used. If there is not a default master key, OBS will create one and use it.  |
        customer_algorithm  |
        const char *  |
        No  |
        Explanation: Indicates a decryption algorithm. This header is included in a response if SSE-C is used. Restrictions: None Value range: AES256 (AES256 decryption algorithm) Default value: None  |
        customer_key_md5  |
        const char *  |
        No  |
        Explanation: Indicates the MD5 value of a key used to decrypt objects. This header is included in a response if SSE-C is used. Restrictions: Base64-encoded MD5 value of the key, for example, 4XvB3tbNTN+tIEVa0/fGaQ==. Value range: Base64-encoded MD5 value of the key ID. Default value: None  |
        bucket_location  |
        const char *  |
        No  |
        Explanation: Indicates the region where the bucket resides. Restrictions: None Value range: None Default value: None  |
        obs_version  |
        const char *  |
        No  |
        Explanation: OBS version of the bucket. Restrictions: None Value range:
        restore  |
        const char *  |
        No  |
        Explanation: Restoration status of an object. Examples: ongoing-request="true" (the object is being restored); ongoing-request="false", expiry-date="Wed, 7 Nov 2012 00:00:00 GMT" (the object has been restored) expiry-date indicates when the restored object will expire. Restrictions: For an Archive object that is being restored or has been restored, this header is returned. Value range: None Default value: None  |
        obs_object_type  |
        const char *  |
        No  |
        Explanation: Type of the object. Restrictions: This header is returned only when the object is not a Normal object. Value range: Appendable Default value: None  |
        obs_next_append_position  |
        const char *  |
        No  |
        Explanation: Indicates the position to be provided for the next request. Restrictions: This header is returned only when the object is an Appendable object. Value range: None Default value: None  |
        obs_head_epid  |
        const char *  |
        No  |
        Explanation: Enterprise project ID for the current bucket. Users who have enabled the enterprise project function can obtain the ID from the enterprise project service. Restrictions: The value is a UUID. This parameter is not required if you have not enabled an enterprise project. Value range: None Default value: None  |
        reserved_indicator  |
        const char *  |
        No  |
        Parameter  |
        Type  |
        Description  |
        message  |
        const char*  |
        Explanation: Error details in the XML error response body. Restrictions: None Value range: See Error Codes. Default value: None  |
        resource  |
        const char*  |
        Explanation: Bucket or object related to the error. Restrictions: None Value range: None Default value: None  |
        further_details  |
        const char*  |
        Explanation: The value of the FurtherDetails element in the XML error response body. Restrictions: None Value range: None Default value: None  |
        extra_details_count  |
        int  |
        Explanation: The number of other elements in the XML error response body. Restrictions: None Value range: None Default value: None  |
        extra_details  |
        Explanation: Values of other elements in the XML error response body. Restrictions: None  |
        error_headers_count  |
        int  |
        Explanation: Number of headers in error_headers. Restrictions: None Value range: None Default value: None  |
        error_headers  |
        char**  |
        Explanation: All response headers that contain the error. Restrictions: None Value range: None Default value: None  |
        Parameter  |
        Type  |
        Description  |
        name  |
        char *  |
        No  |
        Explanation: Key of a property. Restrictions: None Value range: None Default value: None  |
        value  |
        char *  |
        No  |
        Explanation: Property value. Restrictions: None Value range: None Default value: None  |
        Value  |
        Description  |
        OBS_STATUS_OK  |
        The request is successful.  |
        OBS_STATUS_InitCurlFailed  |
        Failed to initialize curl.  |
        OBS_STATUS_InternalError  |
        Internal error.  |
        OBS_STATUS_OutOfMemory  |
        The local memory is insufficient.  |
        OBS_STATUS_FailedToIInitializeRequest  |
        Failed to initialize the request.  |
        OBS_STATUS_ConnectionFailed  |
        Network connection failed.  |
        OBS_STATUS_XmlParseFailure  |
        Failed to parse the XML file.  |
        OBS_STATUS_NameLookupError  |
        Domain name resolution failed.  |
        OBS_STATUS_FailedToConnect  |
        Failed to connect to the server.  |
        OBS_STATUS_PartialFile  |
        Network transmission.  |
        OBS_STATUS_InvalidParameter  |
        Invalid parameter.  |
        OBS_STATUS_NoToken  |
        The current number of concurrent tasks exceeds the maximum number (1000 by default). Use the set_online_request_max_count function to adjust the maximum number of concurrent tasks.  |
        OBS_STATUS_OpenFileFailed  |
        Failed to open the file.  |
        OBS_STATUS_AccessDenied  |
        The request is rejected.  |
        OBS_STATUS_MalformedPolicy  |
        The format of the request policy is incorrect.  |
        OBS_STATUS_MalformedXML  |
        The XML request format is incorrect.  |
        OBS_STATUS_MethodNotAllowed  |
        The request method is not allowed.  |
        OBS_STATUS_SignatureDoesNotMatch  |
        The signatures do not match. Check whether the AK, SK, and token are correct.  |
        OBS_STATUS_ServiceUnavailable  |
        Server exception.  |
        OBS_STATUS_SlowDown  |
        The request frequency is too high.  |
        Parameter  |
        Type  |
        Description  |
        buffer_size  |
        int  |
        Yes  |
        Explanation: Length of the buffer. Restrictions: None Value range: None Default value: None  |
        buffer  |
        char *  |
        Yes  |
        Explanation: Data buffer to be downloaded. Data in this buffer is copied to callback_data to download data. Restrictions: None Value range: None Default value: None  |
        callback_data  |
        void *  |
        Yes  |
        Parameter  |
        Type  |
        Description  |
        key  |
        char *  |
        Yes  |
        Explanation: Object name Restrictions: None Value range: None Default value: None  |
        version_id  |
        char *  |
        No  |
        Explanation: Object version ID. If the object is not a versioned object, set version_id to NULL. Restrictions: None Value range: None Default value: None  |
        Parameter  |
        Type  |
        Description  |
        start_byte  |
        uint64_t  |
        No  |
        Explanation: Start position for object download. Restrictions: None Value range: 0 (included) to the object length minus 1 (not included), in bytes Default value: 0 (indicating that the download starts from the first byte of the object)  |
        byte_count  |
        uint64_t  |
        No  |
        Explanation: Specifies the length to be downloaded. Restrictions:
        download_limit  |
        uint64_t  |
        No  |
        Explanation: Bandwidth limit for single connection requests. Restrictions: None Value range: 819200 to 838860800, in bit/s Default value: None  |
        if_modified_since  |
        int64_t  |
        No  |
        Explanation: The request succeeds if the object has been modified since the specified time; otherwise, an error is returned. Restrictions: None Value range: None Default value: None  |
        if_not_modified_since  |
        int64_t  |
        No  |
        Explanation: The request succeeds if the object has not been modified since the specified time; otherwise, an error is returned. Restrictions: None Value range: None Default value: None  |
        if_match_etag  |
        char *  |
        No  |
        Explanation: Preset ETag. If the ETag of the object to be downloaded or copied is the same as the preset ETag, the request succeeds. Otherwise, an error is returned. Restrictions: None Value range: The value must contain 32 characters. Default value: None  |
        if_not_match_etag  |
        char *  |
        No  |
        Explanation: Preset ETag. If the ETag of the object to be downloaded or copied is different from the preset ETag, the request succeeds. Otherwise, an error is returned. Restrictions: None Value range: The value must contain 32 characters. Default value: None  |
        image_process_config  |
        No  |
        Explanation: Image processing parameters. Restrictions: None  |
        Parameter  |
        Type  |
        Description  |
        image_process_mode  |
        No  |
        Explanation: Image processing parameters. Restrictions: None Value range: For details, see image_process_mode_type.  |
        cmds_stylename  |
        char *  |
        No  |
        Explanation: Image processing parameters. Restrictions: None Value range: None Default value: None  |
        Value  |
        Description  |
        obs_image_process_invalid_mode  |
        Default invalid value.  |
        obs_image_process_cmd  |
        Image processing parameters start with image.  |
        obs_image_process_style  |
        Image processing parameters start with style.  |
        Parameter  |
        Type  |
        Description  |
        encryption_type  |
        No  |
        Explanation: Encryption type. Restrictions: None Value range: For details, see obs_encryption_type.  |
        kms_server_side_encryption  |
        char *  |
        No  |
        Explanation: Indicates that SSE-KMS is used for server-side encryption. Restrictions: None Value range:
        kms_key_id  |
        char *  |
        No  |
        Explanation: Key ID. If the SSE-KMS encryption is used with a specified key, the key ID is required. Restrictions: This header can only be used when you specify kms for the kms_server_side_encryption header. Value range: To obtain the key ID, see Viewing a CMK. Default value: If you specify kms for encryption but do not specify a key ID, the default master key will be used. If there is not a default master key, OBS will create one and use it.  |
        ssec_customer_algorithm  |
        char *  |
        No  |
        Explanation: Indicates the algorithm used to encrypt an object. Restrictions: The header is used only in SSE-C mode. Value range: AES256 (AES256 encryption algorithm) Default value: None  |
        ssec_customer_key  |
        char *  |
        No  |
        Explanation: Indicates the key used to encrypt an object. Restrictions: The header is used only in SSE-C mode. Value range: Base64-encoded 256-bit key Default value: None  |
        des_ssec_customer_algorithm  |
        char *  |
        No  |
        Explanation: Indicates the algorithm used to decrypt a source object. Restrictions: The header is used only in SSE-C mode. Value range: None Default value: None  |
        des_ssec_customer_key  |
        char *  |
        No  |
        Explanation: Indicates the key used to decrypt the source object. Restrictions: The header is used only in SSE-C mode. Value range: None Default value: None  |
Code Examples: Conditional Download
#include "eSDKOBS.h" #include <stdio.h> #include <sys/stat.h> // The response callback function. The content of properties in the callback can be recorded in callback_data (custom callback data). obs_status response_properties_callback(const obs_response_properties *properties, void *callback_data); obs_status get_object_data_callback(int buffer_size, const char *buffer, void *callback_data); void get_object_complete_callback(obs_status status, const obs_error_details *error, void *callback_data); typedef struct get_object_callback_data { FILE *outfile; obs_status ret_status; }get_object_callback_data; FILE * write_to_file(char *localfile); int main() { // The following code shows how to use the get_object function to download an object to a local file: // Call the obs_initialize method at the program entry to initialize global resources such as the network and memory. obs_initialize(OBS_INIT_ALL); obs_options options; // Create and initialize options, including the access domain name (host_name), access keys (access_key_id and access_key_secret), bucket name (bucket_name), and bucket storage class (storage_class). init_obs_options(&options); // Enter the endpoint corresponding to the bucket for host_name. CN-Hong Kong is used here as an example. Replace it with the one in your actual situation. options.bucket_options.host_name = "obs.ap-southeast-1.myhuaweicloud.com"; // Hard-coded or plaintext AK and SK are risky. For security purposes, encrypt your AK and SK and store them in the configuration file or environment variables. // In this example, the AK and SK are stored in environment variables for identity authentication. Before running the code in this example, configure local environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY. options.bucket_options.access_key = getenv("ACCESS_KEY_ID"); options.bucket_options.secret_access_key = getenv("SECRET_ACCESS_KEY"); // Specify the bucket name, for example, example-bucket-name. char * bucketName = "example-bucket-name"; options.bucket_options.bucket_name = bucketName; // Set the name of the local file to which the object is downloaded. char *file_name = "./example_get_file_test"; obs_object_info object_info; // Set the object to be downloaded. memset(&object_info, 0, sizeof(obs_object_info)); object_info.key = "example_get_file_test"; object_info.version_id = NULL; //Set the structure for storing the downloaded object data based on service requirements. get_object_callback_data data; data.ret_status = OBS_STATUS_BUTT; data.outfile = write_to_file(file_name); // Define parameters for range-based download. obs_get_conditions getcondition; memset(&getcondition, 0, sizeof(obs_get_conditions)); init_get_properties(&getcondition); getcondition.if_match_etag = "34a7ef8cc629583f3cdd882791f31351"; // Set the download condition if_modified_since to timestamp 0. getcondition.if_modified_since = 0; getcondition.if_not_match_etag = "34a7ef8cc629583f3cdd882791f31350"; // Set the download condition if_modified_since to timestamp 2147483647. getcondition.if_not_modified_since = INT_MAX; // Define the download callback function. obs_get_object_handler get_object_handler = { { &response_properties_callback, &get_object_complete_callback}, &get_object_data_callback }; get_object(&options, &object_info, &getcondition, 0, &get_object_handler, &data); if (OBS_STATUS_OK == data.ret_status) { printf("get object successfully. \n"); } else { printf("get object failed(%s).\n", obs_get_status_name(data.ret_status)); } fclose(data.outfile); // Release the allocated global resources. obs_deinitialize(); } // The response callback function. The content of properties in the callback can be recorded in callback_data (custom callback data). obs_status response_properties_callback(const obs_response_properties *properties, void *callback_data) { if (properties == NULL) { printf("error! obs_response_properties is null!"); if (callback_data != NULL) { obs_sever_callback_data *data = (obs_sever_callback_data *)callback_data; printf("server_callback buf is %s, len is %llu", data->buffer, data->buffer_len); return OBS_STATUS_OK; } else { printf("error! obs_sever_callback_data is null!"); return OBS_STATUS_OK; } } // Print the response. #define print_nonnull(name, field) \ do { \ if (properties-> field) { \ printf("%s: %s\n", name, properties->field); \ } \ } while (0) print_nonnull("request_id", request_id); print_nonnull("request_id2", request_id2); print_nonnull("content_type", content_type); if (properties->content_length) { printf("content_length: %llu\n", properties->content_length); } print_nonnull("server", server); print_nonnull("ETag", etag); print_nonnull("expiration", expiration); print_nonnull("website_redirect_location", website_redirect_location); print_nonnull("version_id", version_id); print_nonnull("allow_origin", allow_origin); print_nonnull("allow_headers", allow_headers); print_nonnull("max_age", max_age); print_nonnull("allow_methods", allow_methods); print_nonnull("expose_headers", expose_headers); print_nonnull("storage_class", storage_class); print_nonnull("server_side_encryption", server_side_encryption); print_nonnull("kms_key_id", kms_key_id); print_nonnull("customer_algorithm", customer_algorithm); print_nonnull("customer_key_md5", customer_key_md5); print_nonnull("bucket_location", bucket_location); print_nonnull("obs_version", obs_version); print_nonnull("restore", restore); print_nonnull("obs_object_type", obs_object_type); print_nonnull("obs_next_append_position", obs_next_append_position); print_nonnull("obs_head_epid", obs_head_epid); print_nonnull("reserved_indicator", reserved_indicator); int i; for (i = 0; i < properties->meta_data_count; i++) { printf("x-obs-meta-%s: %s\n", properties->meta_data[i].name, properties->meta_data[i].value); } return OBS_STATUS_OK; } obs_status get_object_data_callback(int buffer_size, const char *buffer, void *callback_data) { get_object_callback_data *data = (get_object_callback_data *)callback_data; size_t wrote = fwrite(buffer, 1, buffer_size, data->outfile); return ((wrote < (size_t)buffer_size) ? OBS_STATUS_AbortedByCallback : OBS_STATUS_OK); } void get_object_complete_callback(obs_status status, const obs_error_details *error, void *callback_data) { get_object_callback_data *data = (get_object_callback_data *)callback_data; data->ret_status = status; } FILE * write_to_file(char *localfile) { FILE *outfile = 0; if (localfile) { struct stat buf; if (stat(localfile, &buf) == -1) { outfile = fopen(localfile, "wb"); } else { outfile = fopen(localfile, "a"); } if (!outfile) { fprintf(stderr, "\nERROR: Failed to open output file %s: ", localfile); return outfile; } } else { fprintf(stderr, "\nERROR: Failed to open output file, it's NULL, write object to stdout.", localfile); outfile = stdout; } return outfile; }
