Help Center/ Object Storage Service/ SDK Reference/ C/ Getting Started (SDK for C)/ Downloading an Object (SDK for C)
Updated on 2026-08-03 GMT+08:00
If you have any questions during development, post them on the Issues page of GitHub.
This example shows how to download an object from a bucket to a directory and save the object as test.
Sample code:
static void test_get_object()
char *file_name = "./test";
obs_object_info object_info;
// Create and initialize options, including the access domain name (host_name), access keys (access_key_id and access_key_secret), bucket name (bucket_name), and bucket storage class (storage_class).
obs_options options;
init_obs_options(&options);
// Enter the endpoint corresponding to the bucket for host_name. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
options.bucket_options.host_name = "obs.ap-southeast-1.myhuaweicloud.com";
options.bucket_options.bucket_name = "<Your bucketname>";
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY.
// Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
options.bucket_options.access_key = getenv("ACCESS_KEY_ID");
options.bucket_options.secret_access_key = getenv("SECRET_ACCESS_KEY");
// Set the object to be downloaded.
memset(&object_info, 0, sizeof(obs_object_info));
object_info.key = "<object key>";
object_info.version_id = "<object version ID>";
// Customize the structure for storing downloaded object data based on service requirements.
get_object_callback_data data;
data.ret_status = OBS_STATUS_BUTT;
data.outfile = write_to_file(file_name);
// Define range download parameters.
obs_get_conditions getcondition;
memset(&getcondition, 0, sizeof(obs_get_conditions));
init_get_properties(&getcondition);
// Customize callback function for download.
obs_get_object_handler get_object_handler =
{ &response_properties_callback, &get_object_complete_callback},
&get_object_data_callback
get_object(&options, &object_info, &getcondition, 0, &get_object_handler, &data);
if (OBS_STATUS_OK == data.ret_status) {
printf("get object successfully. \n");
else
printf("get object failed(%s).\n", obs_get_status_name(data.ret_status));
fclose(data.outfile);
} Parent topic: Getting Started (SDK for C)
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
