On this page
Before You Start
Updated on 2024-12-25 GMT+08:00
This section describes the version compatibility and important notes about the C SDK of Object Storage Service (OBS).
Compatibility
  • 3.*.* is compatible with 3.0.0.
  • 3.*.* is incompatible with 2.*.*.
  • 3.*.* is incompatible with 1.*.*.
  • Arm compilation environment:
    NAME="EulerOS"
    VERSION="2.0 (SP8)"
    ID="euleros"
    ID_LIKE="rhel fedora centos"
    VERSION_ID="2.0"
    PRETTY_NAME="EulerOS 2.0 (SP8)"
    ANSI_COLOR="0;31"
    Kernel version:
    4.19.36-vhulk1905.1.0.h276.eulerosv2r8.aarch64
    gcc/g++ version:
    gcc (GCC) 10.3.0/g++ (GCC) 10.3.0
  • Linux compilation environment:
    NAME="CentOS Linux"
    VERSION="7 (Core)"
    ID="centos"
    ID_LIKE="rhel fedora"
    VERSION_ID="7"
    PRETTY_NAME="CentOS Linux 7 (Core)"
    ANSI_COLOR="0;31"
    CPE_NAME="cpe:/o:centos:centos:7"
    HOME_URL="https://www.centos.org/"
    BUG_REPORT_URL="https://bugs.centos.org/"
    CENTOS_MANTISBT_PROJECT="CentOS-7"
    CENTOS_MANTISBT_PROJECT_VERSION="7"
    REDHAT_SUPPORT_PRODUCT="centos"
    REDHAT_SUPPORT_PRODUCT_VERSION="7"
    Kernel version:
    3.10.0-957.5.1.el7.x86_64
    gcc/g++ version:
    The required environments for compiling the SDK binary package are listed above. Compatibility is not guaranteed for other kernels and operating systems. If you need to use other operating systems or kernel versions, use the open-source code to compile on your own.
Important Notes
NOTICE:
If you have any questions during development, post them on the Issues page of GitHub.
  • Ensure that you are familiar with OBS basic concepts, such as buckets, objects, and access keys (AK and SK).
  • After an API call is complete using an instance of ObsClient, view whether an exception is thrown. If no, the API call was successful. If yes, the operation failed. You can check the error information from SDK Error Handling.
  • Some features are available only for some regions. If 405 HTTP status code is returned for a certain feature API, check whether the region supports that feature.
