Deleting an Object
If you have any questions during development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
This example deletes object objectname from bucket bucketname.
The example code is as follows:
obsClient.deleteObject({ Bucket : 'bucketname', Key : 'objectname' }, function (err, result) { if(err){ console.error('Error-->' + err); }else{ console.log('Status-->' + result.CommonMsg.Status); } });
- This example only deletes a single object. To delete objects in a batch, traverse objects and list to-be-deleted objects on your own.
- For details about deletion, see Deleting Objects.
