Getting Started with Common Practices
You can use the common practices provided by APIG to meet your service requirements.
Practice |
Description |
In addition to IAM and app authentication, APIG also supports custom authentication with your own authentication system, which can better adapt to your business capabilities. Custom authentication is implemented using the FunctionGraph service. You can create a FunctionGraph function so that APIG can invoke it to authenticate requests for your API. |
If the number of requests initiated from public networks for open APIs on APIG is not limited, the continuous increase in users will deteriorate the backend performance. And what's worse, the website or program will break down due to a large number of requests sent by malicious users. The traditional request throttling policies of APIG throttle requests by API, user, credential, and source IP address. However, as users and their demands become more diversified, these traditional policies cannot meet the requirements for more refined rate limiting. To resolve this issue, APIG has launched request throttling 2.0, which is a type of plug-in policy. The 2.0 policies enable you to configure more refined throttling, for example, to throttle requests based on a certain request parameter or tenant. |
