Regions and AZs
Updated on 2023-09-27 GMT+08:00
Definition
A region and availability zone (AZ) identify the location of a data center. You can create resources in a specific region and AZ.
  • Regions are divided based on geographical location and network latency. Public services, such as Elastic Cloud Server (ECS), Elastic Volume Service (EVS), Object Storage Service (OBS), Virtual Private Cloud (VPC), Elastic IP (EIP), and Image Management Service (IMS), are shared within the same region. Regions are classified as universal regions and dedicated regions. A universal region provides universal cloud services for common domains. A dedicated region provides services of the same type only or for specific domains.
  • An AZ contains one or more physical data centers. Each AZ has independent cooling, fire extinguishing, moisture-proof, and electricity facilities. Within an AZ, computing, network, storage, and other resources are logically divided into multiple clusters. AZs in a region are interconnected through high-speed optic fibers. This is helpful if you will deploy systems across AZs to achieve higher availability.
Figure 1 shows the relationship between the region and AZ.
Figure 1 Regions and AZs
Huawei Cloud provides services in many regions around the world. You can select a region and AZ as needed. For more information, see Global Products and Services.
How to Select a Region?
When selecting a region, consider the following factors:
  • Location
    Select a region close to you or your target users to reduce network latency and improve access rate.
    Chinese mainland regions provide basically the same infrastructure, BGP network quality, as well as operations and configurations on resources. If you or your target users are in the Chinese mainland, you do not need to consider the network latency differences when selecting a region.
    • If you or your target users are in the Asia Pacific region, except the Chinese mainland, select the CN-Hong Kong, AP-Bangkok, or AP-Singapore region.
    • If you or your target users are in South Africa, select the AF-Johannesburg region.
    • If you or your target users are in Europe, select the EU-Paris region.
    • If you or your target users are in Latin America, select the LA-Santiago region.
      The LA-Santiago region is located in Chile.
  • Resource price
    Resource prices may vary in different regions. For details, see Product Pricing Details.
Selecting an AZ
When deploying resources, consider your applications' requirements on disaster recovery (DR) and network latency.
  • For high DR capability, deploy resources in different AZs within the same region.
  • For lower network latency, deploy resources in the same AZ.
Regions and Endpoints
When using an API to access resources, you must specify a region and endpoint. For more information about regions and endpoints, see Regions and Endpoints.
