Arrears
When the settlement period of your cloud services ends, bills are generated and costs are deducted from your account. If there is not enough balance in your account, your account will be in arrears. If you want to continue using your cloud services, you will need to top up your account in a timely manner.
Impact of Arrears
Once a yearly/monthly subscription has expired or a pay-per-use resource goes into arrears, Huawei Cloud provides a period of time during which you can renew or top up your accounts. For details, see What Is a Grace Period of Huawei Cloud? How Long Is It? and What Is a Retention Period of Huawei Cloud? How Long Is It?
- Yearly/Monthly
This is a pre-paid billing mode, so you can continue using yearly/monthly CCE resources even if your account is in arrears. However, you cannot perform operations such as purchasing clusters, upgrading the cluster specifications, or renewing CCE resources, because they will generate new expenditures.
Figure 1 Lifecycle of a yearly/monthly resource
- Pay-per-Use
If your account is insufficient to pay your amount due, your account will go into arrears and the resources will enter the grace period. Pay-per-use resources are not stopped immediately. You are still responsible for expenditures generated during the grace period. You can view the expenditures on the Overview page in Billing Center and pay any past due balance as needed.
If your account is still in arrears after the grace period ends, the resources enter the retention period and their status turns to Frozen. You cannot perform any operations on these resources.
If you do not bring your account current before the retention period ends, CCE clusters and resources like nodes, EVS disks, and EIPs will be released and the data cannot be restored.
Figure 2 Lifecycle of a pay-per-use CCE resource
Avoiding and Handling Arrears
Top up your account as soon as possible. For details, see Topping Up an Account.
If the cluster is no longer needed, you can delete it and other cloud service resources in the cluster to avoid further expenditures.
If your account is in arrears, top up your account in time. If the resource usage becomes stable, you can purchase yearly/monthly resources to reduce costs. For details, see Yearly/Monthly Billing.
