Updated on 2025-09-04 GMT+08:00
Pay-per-Use Billing
Pay-per-use is a postpaid billing mode. If you expect to use resources flexibly, this billing mode is suitable for you. This section describes the billing rules for pay-per-use CCE resources.
Application Scenarios
Pay-per-use billing is good for short-term, bursty, or unpredictable workloads, such as applications for e-commerce flash sales, temporary testing, and scientific computing.
Billed Items
When using CCE, you can select a billing mode for items listed in Table 1 on the CCE console. The related sources (Billed Items) automatically created on the CCE console are billed on a pay-per-use basis by default. For details, see their respective billing descriptions.
Table 1 Items billed on a pay-per-use basis
Billed Item
Resource Type
Cluster
N/A
A cluster is billed on a pay-per-use basis based on the cluster scale and HA mode.
ECS
ECS flavor
vCPUs and memory are billed on a pay-per-use basis.
EVS disk
If an EVS disk (a system disk or a data disk) is created along with a pay-per-use ECS, the EVS disk is also billed on a pay-per-use basis.
EIP
An EIP billed by bandwidth or traffic can be bound to a pay-per-use ECS created on the CCE console, but cannot be added to a shared bandwidth on the CCE console. If you want to add an EIP to a shared bandwidth, purchase one on the EIP console and then bind it to an ECS.
If an EIP is purchased along with a pay-per-use ECS and the EIP is billed by bandwidth, the bandwidth is also billed on a pay-per-use basis.
Billed Usage Period
The pay-per-use CCE resource usage is calculated by the second and billed every hour (GMT+08:00). Once settlement is complete, it enters a new billed usage period. The billing starts when a cluster or node is launched and ends when the cluster or node is deleted.
It takes a certain time to launch a CCE cluster or node. The billing starts from the time when the cluster or node is successfully created. You can view the time in Operation Records on the CCE console.
For example, if you purchased a pay-per-use CCE cluster at 08:45:30 and deleted it at 08:55:30, you are billed for the 600 seconds from 08:45:30 to 08:55:30.
Impact of Arrears
Figure 1 shows the statuses a pay-per-use resource can have throughout its lifecycle. After a resource is purchased, it enters the valid period and runs normally during this period. If your account goes into arrears, the resource enters a grace period and then a retention period.
Figure 1 Lifecycle of a pay-per-use CCE resource
Arrears Reminder
You will be billed for pay-per-use resource after each billed usage period ends. If your account goes into arrears, we will notify you by email, SMS, or in-app message.
Impact of Arrears
If your account is insufficient to pay your amount due, your account will go into arrears and the resources will enter the grace period. Pay-per-use resources are not stopped immediately. You are still responsible for expenditures generated during the grace period. You can view the expenditures on the Overview page in Billing Center and pay any past due balance as needed.
If you do not bring your account balance current before the grace period expires, the resource turns to Frozen and enters a retention period. You cannot perform any operations on a pay-per-use resource in the Frozen state.
If you do not bring your account current before the retention period ends, CCE clusters and resources like nodes, EVS disks, and EIPs will be released and the data cannot be restored.
Billing for a Hibernated Cluster
Generally, after a pay-per-use CCE cluster is hibernated:
  • You will not be billed for the management of the cluster, but other cloud service resources like EVS disks and bandwidth in the cluster will still be billed in their own billing modes.
  • ECSs in the cluster will not stop automatically. To stop all the nodes, select Shut down all nodes in the cluster. You can also stop a node on the ECS console. For details, see Stopping a Node. For details about the billing policies after the nodes are stopped, see Billing for a Stopped Node.
  • Master node resources will be released. If computing resources are insufficient, the subsequent cluster wakeup may fail.
For example, if you purchased a pay-per-use cluster with 50 worker nodes at 09:00:00 and hibernated it at 09:30:00, you are billed for the 30 minutes from 09:00:00 to 09:30:00 within the billed usage period from 09:00:00 to 10:00:00.
Generally, after a pay-per-use node is stopped:
  • Basic resources (vCPUs and memory) will not be charged.
  • Other resources (EVS disks and bandwidth) used by the node are still charged.
  • Basic resources (vCPUs and memory) will be released, so ECS startup may fail. Wait a moment and try again.
  • Basic resources (vCPUs and memory) of ECSs created on a DeH or in an edge AZ will be retained.
If your ECS contains local disks (such as disk-intensive or ultra-high I/O disks), basic resources (vCPUs, memory, and images) and other resources (EVS disks and bandwidth) are still billed after the ECS is stopped. To avoid any additional expenditures, delete the ECS and all its resources.
For details, see Billing for a Stopped ECS.
