- Function Overview
- Product Bulletin
- Billing
- Getting Started
User Guide
- Clusters
- Workloads
- Network
- Storage
- O&M
- Namespaces
- ConfigMaps and Secrets
- Auto Scaling
- Add-ons
- Helm Chart
- Permissions
- Settings
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- Autopilot Cluster Management
- Add-on Management for Autopilot Clusters
Autopilot Cluster Upgrade
- Upgrading a Cluster
- Performing a Pre-upgrade Check for a Cluster
- Performing a Post-upgrade Check for a Cluster
- Backing Up a Cluster
- Obtaining Details About a Specified Cluster Upgrade Booting Task
- Quota Management for Autopilot Clusters
- Tag Management for Autopilot Clusters
Chart Management for Autopilot Clusters
- Uploading a Chart
- Obtaining a Chart List
- Obtaining a Release List
- Creating a Release
- Updating a Chart
- Deleting a Chart
- Updating a Release
- Obtaining a Chart
- Deleting a Release
- Downloading a Chart
- Obtaining Chart Values
- Kubernetes APIs
- Appendix
- Billing
- Workloads
- Network Management
- Can PVs of the EVS Type in a CCE Autopilot Cluster Be Restored After They Are Deleted or Expire?
- Can CCE Autopilot PVCs Detect Underlying Storage Faults?
- How Can I Delete the Underlying Storage If It Remains After a Dynamically Created PVC is Deleted?
- Permissions
Billing Termination
If a CCE Autopilot cluster is no longer used, you can delete the cluster and other cloud service resources used in the cluster to avoid extra expenditures.
Pay-per-Use Resources
If pay-per-use resources, such as clusters and VPC endpoints, are no longer required, you need to delete them in a timely manner.
Packages
Packages are prepaid and stop automatically when they expire.
- Package unsubscription is not supported. If you stop using packages, the resources in the packages will not be consumed.
- If you have enabled auto-renewal, disable it before the auto-renewal deduction date (default seven days before the expiration date) to avoid generating additional expenditures.
Searching for Resources from Bills and Stopping Billing
To ensure that all related resources are deleted, you can search the billing records by resource ID, and then delete the resources you identify in this way. The procedure is as follows:
- Log in to the Huawei Cloud management console and access Billing Center. In the navigation pane, choose Billing > Expenditure Items.
- Locate the row that contains the resource and copy the resource ID.
Figure 1 Copying the resource ID
- Log in to the CCE console. On the top menu bar, select the region where your cluster resides. Select Cluster ID from the filter criteria, and enter the resource ID copied in 2.
Figure 2 Searching for a resource
- Click
in the upper right corner of the cluster and choose Delete Cluster.
You are billed within one hour of when the resource usage is calculated, so a bill may still be generated after the pay-per-use resource is deleted. For example, if you delete a cluster that is billed on an hourly basis at 08:30, the expenditures for the hour from 08:00 to 09:00 are usually not billed until about 10:00.
