- Function Overview
- Product Bulletin
- Billing
- Getting Started
User Guide
- Clusters
- Workloads
- Network
- Storage
- O&M
- Namespaces
- ConfigMaps and Secrets
- Auto Scaling
- Add-ons
- Helm Chart
- Permissions
- Settings
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- Autopilot Cluster Management
- Add-on Management for Autopilot Clusters
Autopilot Cluster Upgrade
- Upgrading a Cluster
- Performing a Pre-upgrade Check for a Cluster
- Performing a Post-upgrade Check for a Cluster
- Backing Up a Cluster
- Obtaining Details About a Specified Cluster Upgrade Booting Task
- Quota Management for Autopilot Clusters
- Tag Management for Autopilot Clusters
Chart Management for Autopilot Clusters
- Uploading a Chart
- Obtaining a Chart List
- Obtaining a Release List
- Creating a Release
- Updating a Chart
- Deleting a Chart
- Updating a Release
- Obtaining a Chart
- Deleting a Release
- Downloading a Chart
- Obtaining Chart Values
- Kubernetes APIs
- Appendix
- Billing
- Workloads
- Network Management
- Can PVs of the EVS Type in a CCE Autopilot Cluster Be Restored After They Are Deleted or Expire?
- Can CCE Autopilot PVCs Detect Underlying Storage Faults?
- How Can I Delete the Underlying Storage If It Remains After a Dynamically Created PVC is Deleted?
- Permissions
Show all
CCE Autopilot Billing Overview
This section describes the billing modes, billed items, billing examples, billing mode change, package renewal, and bills of CCE Autopilot clusters.
- Billing Modes
CCE Autopilot supports two billing modes: pay-per-use and packages. Billing Mode Overview describes the two billing modes in detail.
- Pay-per-use: You can start using CCE Autopilot resources first and then pay as you go.
- Packages are a prepaid model where payment is made before usage, and each package is billed by both the resource quota and the purchase period in the order. Before making a purchase, you must ensure that your account balance is sufficient.
Currently, CCE Autopilot provides vCPU and memory packages required by pods.
You can also change the billing mode later if it no longer meets your needs. For details, see Changing the Billing Mode.
- Billed Items
The billed items of CCE Autopilot clusters include cluster management, pods, VPC endpoints, and other cloud service resources. Billed Items describes the billing factors and formulas of each billed item in detail.
- Billing Examples
Billing Examples provides billing examples and the billing for each billed item.
- Changing the Billing Mode
You can change the billing mode later if it no longer meets your needs. For details, see Changing the Billing Mode.
- Package Renewal
After a package expires, the CCE Autopilot cluster will be billed on a pay-per-use basis and can still run normally. If you want to continue using the package, you need to renew it within the specified period. You can renew the package manually or automatically. For details, see Renewal Overview.
- Bills
In Billing Center, choose Billing and check the CCE Autopilot cluster transactions and bills. For details, see Bills.
- Arrears
If there is no sufficient account balance to pay for your bill and there is no other payment method configured, your account will go into arrears. If you want to continue using your cloud services, you will need to top up your account in a timely manner. For details, see Arrears.
- Stopping Billing
In pay-per-use billing, you can delete a CCE Autopilot cluster that is no longer used to avoid additional expenditures. For details, see Billing Termination.
