On this page
Step 2: Create a VPC Endpoint for Connecting to OBS
Updated on 2023-12-20 GMT+08:00
This section describes how to create a VPC endpoint to access OBS from an on-premises data center.
The required VPC endpoint service is available.
  2. Click in the upper left corner and select the required region and project.
  3. Click Service List and choose Networking > VPC Endpoint.
  4. On the VPC Endpoints page, click Create VPC Endpoint.
    The Create VPC Endpoint page is displayed.
  5. Configure VPC endpoint parameters.
    Table 1 VPC endpoint parameters
    Region
    Specifies the region where the VPC endpoint is to be located.
    Resources in different regions cannot communicate with each other over an intranet. For lower latency and quicker access, select the nearest region.
    Service Category
    There are two options:
    • Cloud services: Select this value if the target VPC endpoint service is a cloud service.
    • Find a service by name: Select this value if the target VPC endpoint service is a private service of your own.
    In this example, select Cloud services.
    Service List
    This parameter is available only when you select Cloud services for Service Category.
    The VPC endpoint service has been created by the O&M personnel and you can directly use it.
    Select the VPC endpoint service for OBS.
    VPC
    Specifies the VPC where the VPC endpoint is to be deployed.
    Tag
    This parameter is optional.
    Specifies the VPC endpoint tag, which consists of a key and a value. You can add up to 10 tags to each VPC endpoint.
    Tag keys and values must meet requirements listed in Table 2.
    Table 2 Tag requirements for VPC endpoints
    Requirement
    Tag key
    • Cannot be left blank.
    • Must be unique for each resource.
    • Can contain a maximum of 36 characters.
    • Cannot start or end with a space or contain special characters =*<>\,|/
    Tag value
    • Can contain a maximum of 43 characters.
  6. Confirm the specifications and click Create Now.
    • If all of the specifications are correct, click Submit.
    • If any of the specifications are incorrect, click Previous to return to the previous page and modify the parameters as needed, and click Submit.
  7. Click Back to VPC Endpoint List after the task is submitted.
    If the status of the VPC endpoint changes from Creating to Accepted, the VPC endpoint for connecting to the VPC endpoint service for OBS is created.
  8. In the VPC endpoint list, click before the target VPC endpoint to view its details.
