- What's New
- Function Overview
- Billing
- Getting Started
User Guide
VPC Endpoint Services
- VPC Endpoint Service Overview
- Creating a VPC Endpoint Service
- Viewing a VPC Endpoint Service
- Deleting a VPC Endpoint Service
- Managing Connections of a VPC Endpoint Service
- Managing Whitelist Records of a VPC Endpoint Service
- Managing Port Mappings of a VPC Endpoint Service
- Managing Tags of a VPC Endpoint Service
- VPC Endpoints
- Accessing OBS
- Using Cloud Eye to Monitor VPC Endpoints
- Using CTS to Audit VPC Endpoints
- Permissions Management
- Quotas
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
API
- Version Management
- Querying VPC Endpoint Services
- Querying Details of a VPC Endpoint Service
- Modifying a VPC Endpoint Service
- Querying Connections to a VPC Endpoint Service
- Accepting or Rejecting a VPC Endpoint
- Querying Whitelist Records of a VPC Endpoint Service
- Batch Adding or Deleting Whitelist Records of a VPC Endpoint Service
- Querying Public VPC Endpoint Services
- Querying Basic Information About a VPC Endpoint Service
- Changing the Name of a VPC Endpoint Service
- Updating Descriptions of VPC Endpoint Connections
- Batch Adding Whitelist Records of a VPC Endpoint Service
- Batch Deleting Whitelist Records of a VPC Endpoint Service
- Updating the Description of a Whitelist Record of a VPC Endpoint Service
- VPC Endpoints
- Resource Quotas
- Tags
- Application Examples
- Appendix
- SDK Reference
- FAQs
More Documents
- Getting Started
- Viewing Summary of a VPC Endpoint Service
- Viewing Port Mappings of a VPC Endpoint Service
- VPC Endpoints
- Permission Management
- FAQs
- Change History
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
APIs for Managing VPC Endpoint Services
- Querying Connections of a VPC Endpoint Service
- Querying the Whitelist Records of a VPC Endpoint Service
- APIs for Managing VPC Endpoints
- Resource Quota
- Tag Function
- Appendix
- Change History
User Guide (Paris Region)
Getting Started
- Operation Guide
- Configuring a VPC Endpoint for Communications Across VPCs of the Same Domain
- Configuring a VPC Endpoint for Communications Across VPCs of Different Domains
- Configuring a VPC Endpoint for Accessing the Private IP Address of OBS over Private Networks
- Configuring a VPC Endpoint for Accessing the Public IP Address of OBS over Public Networks
- Viewing the Summary of a VPC Endpoint Service
- VPC Endpoints
- Quotas
- FAQ
- Change History
API Reference (Paris Region)
- Before You Start
- API Overview
- Calling APIs
APIs
- Querying Details About a VPC Endpoint Service
- Resource Quota
- Tag Function
- Appendix
- Change History
- Getting Started
- VPC Endpoints
- Quotas
- FAQ
- Change History
- Before You Start
- API Overview
- Calling APIs
APIs
- Resource Quota
- Tag Function
- Appendix
- Change History
- User Guide (Ankara Region)
API Reference (Ankara Region)
- Before You Start
- API Overview
- Calling APIs
APIs
- Resource Quota
- Appendix
- Change History
Show all
Step 1: Create a VPC Endpoint Service
To enable communications across two VPCs, you first need to configure a cloud resource (backend resource) in one VPC as a VPC endpoint service.
This section describes how to create a VPC endpoint service by selecting an elastic load balancer as an example backend service in VPC 2 using B.
There is a load balancer in the VPC where you are going to create the VPC endpoint service.
- Click
in the upper left corner and select the required region and project.
- Click Service List and choose Networking > VPC Endpoint.
- In the navigation pane on the left, choose VPC Endpoint > VPC Endpoint Services. In the upper right corner, click Create VPC Endpoint Service.
The Create VPC Endpoint Service page is displayed.
- Configure required parameters.
Table 1 Parameters for creating a VPC endpoint service Parameter
Region
Specifies the region where the VPC endpoint service is to be deployed.
Resources in different regions cannot communicate with each other over an intranet. For lower latency and quicker access, select the nearest region.
VPC
Specifies the VPC where the VPC endpoint service is to be deployed.
Service Type
Specifies the type of the VPC endpoint service. The type can only be Interface.
Connection Approval
Specifies whether the connection between a VPC endpoint and a VPC endpoint service requires approval from the owner of the VPC endpoint service.
You can enable or disable Connection Approval.
When Connection Approval is enabled, any VPC endpoint for connecting to the VPC endpoint service needs to be approved. For details, see step 7.
Port Mapping
Specifies the protocol and ports used for communications between the VPC endpoint service and a VPC endpoint. The protocol is TCP.
- Service Port: provided by the backend resource bound to the VPC endpoint service.
- Terminal Port: provided by the VPC endpoint, allowing you to access the VPC endpoint service.
The service and terminal port numbers range from 1 to 65535. A maximum of 50 port mappings can be added at a time.
Accessing a VPC endpoint service from a VPC endpoint is to access the service port from the associated terminal port.
Backend Resource Type
Specifies the backend resource that provides services to be accessed.
The following backend resource types are supported:
- Elastic load balancer: Backend resources of this type suit services that receive high access traffic and demand high reliability and disaster recovery (DR) performance.
- ECS: Backend resources of this type serve as servers.
- BMS: Backend resources of this type serve as servers.
In this example, select Elastic load balancer.NOTE:
- For the security group associated with the backend resource configured for the VPC endpoint service, add an inbound rule, with Source set to 198.19.128.0/17. For details, see section "Adding a Security Group Rule" in the Virtual Private Cloud User Guide.
- If you configure a load balancer as the backend resource for the VPC endpoint service, and enable access control for the listener associated with the load balancer, ensure to allow traffic from 198.19.128.0/17.
Load Balancer
When Backend Resource Type is set to Elastic load balancer, select the load balancer that provides services from the drop-down list.
If an elastic load balancer is used as the backend resource, the source IP address received by the VPC endpoint service is not the real address of the client.
Tag
This parameter is optional.
Specifies the VPC endpoint service tag, which consists of a key and a value. You can add up to 10 tags to each VPC endpoint service.
Tag keys and values must meet requirements listed in Table 2.
Table 2 Tag requirements for VPC endpoint services Parameter
Requirement
Tag key
- Cannot be left blank.
- Must be unique for each resource.
- Can contain a maximum of 36 characters.
- Cannot start or end with a space or contain special characters =*<>\,|/
Tag value
- Can contain a maximum of 43 characters.
- Click Create Now.
- Click Back to VPC Endpoint Service List to view the newly-created VPC endpoint service.
- In the VPC endpoint service list, locate the target VPC endpoint service and click its name to view its details.
