Help Center/
Virtual Private Cloud/
User Guide (Kuala Lumpur Region)/
Virtual IP Address/
Disabling Source/Destination Check for an ECS NIC
Updated on 2024-04-11 GMT+08:00
If a virtual IP address is used in an HA load balancing cluster, you need to disable source/destination check for ECS NICs.
- In the upper left corner of the page, click
. In the service list, choose Computing > Elastic Cloud Server. - In the ECS list, click the ECS name.
- On the displayed ECS details page, click the NICs tab.
- Check that Source/Destination Check is disabled.
Parent topic: Virtual IP Address
