Replicating a Route
Updated on 2024-04-11 GMT+08:00
This section describes how to replicate routes among all route tables of a VPC. VPC route tables include the default and custom route tables.
Notes and Constraints
Table 1 shows whether routes of different types can be replicated to default or custom route tables.
For example, if the next hop type of a route is a server, this route can be replicated to both default or custom route tables. If the next hop type of a route is a Direct Connect gateway, the route cannot be replicated to the default route table, but can be replicated to a custom route table.
Table 1 Route replication
Next Hop Type
Can Be Replicated to Default Route Table
Can Be Replicated to Custom Route Table
Local
No
No
Server
Yes
Yes
Extension NIC
Yes
Yes
VPN gateway
No
Yes
No
Yes
NAT gateway
Yes
Yes
VPC peering connection
Yes
Yes
Virtual IP address
Yes
Yes
  • If the Direct Connect service is enabled by call or email, the routes delivered to the default route table cannot be replicated to a custom route table.
  1. Click in the upper left corner and choose Network > Virtual Private Cloud.
    The Virtual Private Cloud page is displayed.
  2. In the navigation pane on the left, choose Virtual Private Cloud > Route Tables.
  3. In the route table list, locate the row that contains the route table you want to replicate routes from and click Replicate Route in the Operation column.
  4. Select the target route table that you want to replicate route to and the routes to be replicated as prompted.
    The listed routes are those that do not exist in the target route table. You can select one or more routes to replicate to the target route table.
  5. Click OK.
