Step 3: Assign an EIP and Bind It to an ECS
You can assign an EIP and bind it to an ECS so that the ECS can access the Internet.
Assigning an EIP
 - Click
 in the upper left corner and choose Network > Elastic IP. - On the displayed page, click Assign EIP.
 - Set the parameters as prompted.
Table 1 Parameter descriptions Parameter
Example Value
Region
Regions are geographic areas that are physically isolated from each other. The networks inside different regions are not connected to each other, so resources cannot be shared across different regions. For lower network latency and faster access to your resources, select the region nearest you. The region selected for the EIP is its geographical location.
N/A
EIP Type
Dynamic BGP: Dynamic BGP provides automatic failover and chooses the optimal path when a network connection fails.
Dynamic BGP
Billed By
The following bandwidth types are available:- Bandwidth: You specify a maximum bandwidth and pay for the amount of time you use the bandwidth. This is suitable for scenarios with heavy or stable traffic.
 - Traffic: You specify a maximum bandwidth and pay for the total traffic you use. This is suitable for scenarios with light or sharply fluctuating traffic.
 - Shared Bandwidth: The bandwidth can be shared by multiple EIPs and is suitable for scenarios with staggered traffic.
Bandwidth
Bandwidth
The bandwidth size in Mbit/s.
100
EIP Name
The name of the EIP.
eip-test
Bandwidth Name
The name of the bandwidth.
bandwidth
Tag
The EIP tags. Each tag contains a key and value pair.
The tag key and value must meet the requirements listed in Table 2.
- Key: Ipv4_key1
 - Value: 3005eip
Quantity
The number of EIPs you want to purchase.
Enterprise Project
The enterprise project that the EIP belongs to.
An enterprise project lets you manage cloud resources and personnel by enterprise project. The default project is default.
For details about creating and managing enterprise projects, see the Enterprise Management User Guide.
default
Table 2 EIP tag requirements Parameter
Requirement
Example Value
Key
- Cannot be left blank.
 - Must be unique for each EIP.
 - Can contain a maximum of 36 characters.
 - Can contain letters, digits, underscores (_), and hyphens (-).
Ipv4_key1
Value
- Can contain a maximum of 43 characters.
 - Can contain letters, digits, underscores (_), periods (.), and hyphens (-).
3005eip
 - Click Create Now.
 - Click Submit.
