Help Center/
      Virtual Private Cloud/
        User Guide (Kuala Lumpur Region)/
        VPC Peering Connection/
      Obtaining the Peer Project ID of a VPC Peering Connection
        Updated on 2024-04-11 GMT+08:00
If you create a VPC peering connection between two VPCs in different accounts, you can refer to this section to obtain the project ID of the region that the peer VPC resides.
   Parent topic: VPC Peering Connection
