On this page
Modifying a Network ACL Rule
Updated on 2024-04-11 GMT+08:00
Modify an inbound or outbound network ACL rule based on your network security requirements.
  1. Click in the upper left corner and choose Network > Virtual Private Cloud.
    The Virtual Private Cloud page is displayed.
  2. In the navigation pane on the left, choose Access Control > Network ACLs.
  3. Locate the target network ACL and click its name to switch to the page showing details of that particular network ACL.
  4. On the Inbound Rules or Outbound Rules tab, locate the row that contains the target rule and click Modify in the Operation column. In the displayed dialog box, configure parameters as prompted. Table 1 lists the parameters to be configured.
    Table 1 Parameter descriptions
    Example Value
    Type
    The network ACL type. This parameter is mandatory. You can select a value from the drop-down list. Currently, only IPv4 and IPv6 are supported.
    IPv4
    Action
    The action in the network ACL. This parameter is mandatory. You can select a value from the drop-down list. Currently, the value can be Allow or Deny.
    Allow
    Protocol
    The protocol supported by the network ACL. This parameter is mandatory. You can select a protocol from the drop-down list.
    You can select TCP, UDP, ICMP, or All.
    TCP
    Source
    The source from which the traffic is allowed. The source can be an IP address or IP address range.
    • IP address:
      • Single IP address: 192.168.10.10/32 (IPv4); 2002:50::44/128 (IPv6)
      • All IP addresses: 0.0.0.0/0 (IPv4); ::/0 (IPv6)
      • IP address range: 192.168.1.0/24 (IPv4); 2407:c080:802:469::/64 (IPv6)
    0.0.0.0/0
    Source Port Range
    The source port number or port number range. The value ranges from 1 to 65535. For a port number range, enter two port numbers connected by a hyphen (-). For example, 1-100.
    22, or 22-30
    Destination
    The destination to which the traffic is allowed. The destination can be an IP address or IP address range.
    • IP address:
    0.0.0.0/0
    Destination Port Range
    The destination port number or port number range. The value ranges from 1 to 65535. For a port number range, enter two port numbers connected by a hyphen (-). For example, 1-100.
    You must specify this parameter if TCP or UDP is selected for Protocol.
    22, or 22-30
    Supplementary information about the network ACL rule. This parameter is optional.
    The description can contain a maximum of 255 characters and cannot contain angle brackets (< or >).
    N/A
  5. Click Confirm.
