Importing and Exporting Security Group Rules
You can configure security group rules in an Excel file and import the rules to the security group. You can also export security group rules to an Excel file.
You can import and export security group rules in the following scenarios:
- If you want to back up security group rules locally, you can export the rules to an Excel file.
- If you want to quickly create or restore security group rules, you can import your security group rule file to the security group.
- If you want to quickly apply the rules of one security group to another, you can export and import existing rules.
- If you want to modify multiple rules of the current security group at a time, you can export and import existing rules.
Notes and Constraints
- The security group rules to be imported must be configured based on the template. Do not add parameters or change existing parameters. Otherwise, the import will fail.
- If a security group rule to be imported is the same as an existing one, the security group rule cannot be imported. You can delete the rule and try again.
- Click
in the upper left corner and choose Network > Virtual Private Cloud.
The Virtual Private Cloud page is displayed.
- In the navigation pane on the left, choose Access Control > Security Groups.
The security group list is displayed.
- On the security group list, click the name of the target security group.
- Export and import security group rules.
- Click
to export all rules of the current security group to an Excel file. - Click
to import security group rules from an Excel file into the current security group.
Table 1 describes the parameters in the template for importing rules.Table 1 Template parameters Parameter
Example Value
Direction
The direction in which the security group rule takes effect.- Inbound: Inbound rules control incoming traffic to instances in the security group.
- Outbound: Outbound rules control outgoing traffic from instances in the security group.
Inbound
Protocol & Port
The network protocol used to match traffic in a security group rule. The value can be All, TCP, UDP, GRE, and ICMP.
TCP
Destination port used to match traffic in a security group rule. The value can be from 1 to 65535.
Inbound rules control incoming traffic over specific ports to instances in the security group.
Outbound rules control outgoing traffic over specific ports from instances in the security group.
22, or 22-30
Type
Source IP address version. You can select:- IPv4
- IPv6
IPv4
Source
Source of the security group rule. The value can be an IP address or a security group to allow access from IP addresses or instances in the security group.- IP address:
- Single IP address: 192.168.10.10/32 (IPv4); 2002:50::44/128 (IPv6)
- All IP addresses: 0.0.0.0/0 (IPv4); ::/0 (IPv6)
- IP address range: 192.168.1.0/24 (IPv4); 2407:c080:802:469::/64 (IPv6)
sg-test[96a8a93f-XXX-d7872990c314]
Destination
Destination of the security group rule. The value can be an IP address or a security group to allow access to IP addresses or instances in the security group. For example:
Supplementary information about the security group rule. This parameter is optional.
The security group rule description can contain a maximum of 255 characters and cannot contain angle brackets (< or >).
Last Modified
The time when the security group was modified.
- Click
