Security Group Configuration Examples
- Remotely Logging In to an ECS from a Local Server
 - Remotely Connecting to an ECS from a Local Server to Upload or Download FTP Files
 - Setting Up a Website on an ECS to Provide Services Externally
 - Using ping Command to Verify Network Connectivity
 - Enabling Communications Between Instances in Different Security Groups
 - Allowing External Instances to Access the Database Deployed on an ECS
 - Allowing ECSs to Access Specific External Websites
Precautions
Note the following before configuring security group rules:
- Instances associated with different security groups are isolated from each other by default.
 - Generally, a security group denies all external requests by default.
You need to add inbound rules to allow specific traffic to the instances in the security group.
 - By default, outbound security group rules allow all requests from the instances in the security group to access external resources.
    If outbound rules are deleted, the instances in the security group cannot communicate with external resources. To allow outbound traffic, you need to add outbound rules by referring to Table 1.
Table 1 Default outbound rules in a security group Direction
Protocol & Port
Destination
Outbound
All
0.0.0.0/0
This rule allows the instances in the security group to access any IPv4 address over any port.
Outbound
All
::/0
This rule allows the instances in the security group to access any IPv6 address over any port.
A security group denies all external requests by default. To remotely log in to an ECS in a security group from a local server, add an inbound rule based on the OS running on the ECS.
- To remotely log in to a Linux ECS using SSH, enable port 22. For details, see Table 2.
 - To remotely log in to a Windows ECS using RDP, enable port 3389. For details, see Table 3.
Table 2 Remotely logging in to a Linux ECS using SSH Direction
Protocol & Port
Source
Inbound
TCP: 22
IP address: 0.0.0.0/0
Table 3 Remotely logging in to a Windows ECS using RDP Direction
Protocol & Port
Source
Inbound
TCP: 3389
     If the source is set to 0.0.0.0/0, any IP address can be used to remotely log in to the ECS. To ensure security, set the source to a specific IP address based on service requirements. For details about the configuration example, see Table 4.
By default, a security group denies all external requests. If you need to remotely connect to an ECS from a local server to upload or download files, you need to enable FTP ports 20 and 21.
        Direction  |
        Protocol & Port  |
        Source  |
        Inbound  |
        TCP: 20-21  |
        IP address: 0.0.0.0/0  |
   You must first install the FTP server program on the ECSs and check whether ports 20 and 21 are working properly.
A security group denies all external requests by default. If you have set up a website on an ECS that can be accessed externally, you need to add an inbound rule to the ECS security group to allow access over specific ports, such as HTTP (80) and HTTPS (443).
        Direction  |
        Protocol & Port  |
        Source  |
        Inbound  |
        TCP: 80  |
        Inbound  |
        TCP: 443  |
Ping works by sending an Internet Control Message Protocol (ICMP) Echo Request. To ping an ECS from your PC to verify the network connectivity, you need to add an inbound rule to the security group of the ECS to allow ICMP traffic.
        Direction  |
        Protocol & Port  |
        Source  |
        Inbound  |
        ICMP: All  |
Instances in the same VPC but associated with different security groups cannot communicate with each other. If you want ECSs in security group sg-A to access MySQL databases in security group sg-B, you need to add an inbound rule to security group sg-B to allow access from ECSs in security group sg-A.
        Direction  |
        Protocol & Port  |
        Source  |
        Inbound  |
        TCP: 3306  |
        Security group: sg-A  |
- MySQL: port 3306
 - Oracle: port 1521
 - MS SQL: port 1433
 - PostgreSQL: port 5432
 - Redis: port 6379
        Direction  |
        Protocol & Port  |
        Source  |
        Description  |
        Inbound  |
        TCP: 3306  |
        This rule allows the ECSs in security group sg-A to access the MySQL database service.  |
        Inbound  |
        TCP: 1521  |
        Security group: sg-B  |
        This rule allows the ECSs in security group sg-B to access the Oracle database service.  |
        Inbound  |
        TCP: 1433  |
        IP address: 172.16.3.21/32  |
        This rule allows the ECS whose private IP address is 172.16.3.21 to access the MS SQL database service.  |
        Inbound  |
        TCP: 5432  |
        IP address: 192.168.0.0/24  |
        This rule allows ECSs whose private IP addresses are in the 192.168.0.0/24 network to access the PostgreSQL database service.  |
   In this example, the source is for reference only. Set the source address based on your requirements.
By default, a security group allows all outbound traffic. Table 11 lists the default rules. If you want to allow ECSs to access specific websites, configure the security group as follows:
- Add outbound rules to allow traffic over specific ports to specific IP addresses.
Table 10 Allowing ECSs to access specific external websites Direction
Protocol & Port
Destination
Outbound
TCP: 80
IP address: 132.15.XX.XX
This rule allows ECSs in the security group to access the external website at http://132.15.XX.XX:80.
Outbound
TCP: 443
IP address: 145.117.XX.XX
This rule allows ECSs in the security group to access the external website at https://145.117.XX.XX:443.
 - Delete the original outbound rules that allow all traffic.
Table 11 Default outbound rules in a security group Direction
Protocol & Port
Destination
Outbound
All
0.0.0.0/0
Outbound
All
::/0
