On this page
Route Table
Updated on 2024-04-11 GMT+08:00
Route Tables
A route table contains a set of routes that are used to determine where network traffic from your subnets in a VPC is directed. Each subnet must be associated with a route table. A subnet can only be associated with one route table, but you can associate multiple subnets with the same route table.
  • Default route table: When you create a VPC, the system automatically generates a default route table for the VPC. If you create a subnet in the VPC, the subnet automatically associates with the default route table. The default route table ensures that subnets in a VPC can communicate with each other.
    • You can add routes to, delete routes from, and modify routes in the default route table, but cannot delete the table.
    • When you create a VPC endpoint, VPN or Direct Connect connection, the default route table automatically delivers a route that cannot be deleted or modified.
  • Custom route table: If you do not want to use the default route table, you can create a custom route table and associate it with the subnet. Custom route tables can be deleted if they are no longer required.
    The custom route table associated with a subnet affects only the outbound traffic. The default route table of a subnet controls the inbound traffic.
Route
You can add routes to default and custom route tables and configure the destination, next hop type, and next hop in the routes to determine where network traffic is directed. Routes are classified into system routes and custom routes.
  • System routes: These routes are automatically added by the system and cannot be modified or deleted.
    After a route table is created, the system automatically adds the following system routes to the route table, so that instances in a VPC can communicate with each other.
    • Routes whose destination is 100.64.0.0/10 or 198.19.128.0/20.
    • Routes whose destination is a subnet CIDR block.
      In addition to the preceding system routes, the system automatically adds a route whose destination is 127.0.0.0/8. This is the local loopback address.
  • Custom routes: These are routes that you can add, modify, and delete. The destination of a custom route cannot overlap with that of a system route.
    You can add a custom route and configure the destination, next hop type, and next hop in the route to determine where network traffic is directed. Table 1 lists the supported types of next hops.
    You cannot add two routes with the same destination to a VPC route table even if their next hop types are different. The route priority depends on the destination. According to the longest match routing rule, the destination with a higher matching degree is preferentially selected for packet forwarding.
    Table 1 Next hop type
    Next Hop Type
    Supported Route Table
    Server
    Traffic intended for the destination is forwarded to an ECS in the VPC.
    Extension NIC
    Traffic intended for the destination is forwarded to the extension NIC of an ECS in the VPC.
    VPN gateway
    Traffic intended for the destination is forwarded to a VPN gateway.
    Custom route table
    Direct Connect gateway
    Traffic intended for the destination is forwarded to a Direct Connect gateway.
    Custom route table
    NAT gateway
    Traffic intended for the destination is forwarded to a NAT gateway.
    VPC peering connection
    Traffic intended for the destination is forwarded to a VPC peering connection.
    Virtual IP address
    Traffic intended for the destination is forwarded to a virtual IP address and then sent to active and standby ECSs to which the virtual IP address is bound.
    If you specify the destination when creating a resource, a system route is delivered. If you do not specify a destination when creating a resource, a custom route that can be modified or deleted is delivered.
    For example, when you create a NAT gateway, the system automatically delivers a custom route without a specific destination (0.0.0.0/0 is used by default). In this case, you can change the destination. However, when you create a VPN gateway, you need to specify the remote subnet, that is, the destination of a route. In this case, the system delivers this system route. Do not modify the route destination on the Route Tables page. If you do, the destination will be inconsistent with the configured remote subnet. To modify the route destination, go to the specific resource page and modify the remote subnet, then the route destination will be changed accordingly.
