On this page
Fast-Adding Security Group Rules
Updated on 2024-04-11 GMT+08:00
The fast-adding rule function of security groups allows you to quickly add rules with common ports and protocols for remote login, ping tests, common web services, and database services.
  1. Click in the upper left corner and choose Network > Virtual Private Cloud.
    The Virtual Private Cloud page is displayed.
  2. In the navigation pane on the left, choose Access Control > Security Groups.
    The security group list is displayed.
  3. Locate the row that contains the target security group and click Manage Rule in the Operation column.
    The page for configuring security group rules is displayed.
  4. On the Inbound Rules tab, click Fast-Add Rule.
    The Fast-Add Inbound Rule dialog box is displayed.
  5. Configure required parameters.
    Table 1 Inbound rule parameter description
    Example Value
    Protocols and Ports
    Common protocols and ports are provided for:
    • Remote login and ping
    • Web services
    • Databases
    SSH (22)
    Type
    Source IP address version. You can select:
    • IPv4
    • IPv6
    IPv4
    Source
    Source of the security group rule. The value can be an IP address or a security group to allow access from IP addresses or instances in the security group. You can specify:
    • Single IP address: 192.168.10.10/32 (IPv4); 2002:50::44/127 (IPv6)
    • IP address range: 192.168.1.0/24 (IPv4); 2407:c080:802:469::/64 (IPv6)
    • All IP addresses: 0.0.0.0/0 (IPv4); ::/0 (IPv6)
    • Security group: sg-abc
    If the source is a security group, this rule will apply to all instances associated with the selected security group.
    0.0.0.0/0
    (Optional) Supplementary information about the security group rule.
    The description can contain a maximum of 255 characters and cannot contain angle brackets (< or >).
  6. Click OK.
    The inbound rule list is displayed and you can view your added rule.
  7. On the Outbound Rules tab, click Fast-Add Rule.
    The Fast-Add Outbound Rule dialog box is displayed.
  8. Configure required parameters.
    Table 2 Outbound rule parameter description
    Example Value
    Protocols and Ports
    • Web services
    • Databases
    SSH (22)
    Type
    • IPv4
    • IPv6
    IPv4
    Destination
    Destination of the security group rule. The value can be an IP address or a security group to allow access to IP addresses or instances in the security group. You can specify:
    0.0.0.0/0
  9. Click OK.
    The outbound rule list is displayed and you can view your added rule.
