- What's New
- Function Overview
- Getting Started
User Guide
- Topic Management
- Subscription Management
- Message Template Management
- SMN Operation Recording
- Cloud Eye Monitoring
- Logs
- Permissions Management
- Quotas
- Appendix
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
- APIs
- Examples
- Public Parameters
- Out-of-Date APIs
- Appendix
- SDK Reference
- What Are the Advantages of SMN?
- What Protocols Does SMN Support?
- How Is SMN Billed?
- What Are the Requirements for an SMN Topic Name?
- How Many Topics Can I Create?
- How Many Subscriptions Can Be Added to a Topic?
- How Many Messages Can Be Published to a Topic?
- How Many Message Templates Can I Create?
- What Are the Limitations on SMS Messages?
- Can I Add Subscriptions Using Multiple Protocols to a Topic?
- Can a Topic Creator Change Subscription Protocols in a Topic?
- Can I Change a Subscription Endpoint for a Topic?
- Can I Delete a Published Message?
- Does SMN Ensure That Messages Are Received by Subscription Endpoints?
- Will a Subscriber Receive the Same Message Multiple Times?
- Why Do Subscribers Fail to Receive Messages After I Publish Messages to a Topic?
- What Can I Do When Pictures in an Email Message Cannot Be Displayed?
- Does SMN Always Use the Same Phone Number or Sender Name to Send SMS Messages?
- How Do I Obtain My Account ID?
- How Does a DingTalk, Internal DingTalk, Lark, or WeCom Chatbot Obtain Subscription Endpoints?
- Videos
More Documents
- Overview
- Getting Started
- Topic Management
- Logs
- Quotas
- Appendix
- Change History
- API Reference
User Guide (Paris Region)
- Overview
- Getting Started
- Topic Management
- Logs
- Quotas
- Appendix
- Change History
- API Reference (Paris Region)
- Overview
- Getting Started
- Topic Management
- Logs
- Quotas
- Appendix
- Change History
- API Reference (Kuala Lumpur Region)
User Guide (Ankara Region)
- Overview
- Getting Started
- Topic Management
- Quotas
- Appendix
- Change History
- API Reference (Ankara Region)
Show all
CTS Traces
After CTS is enabled, it starts recording operations on cloud resources. You can view the operation records of the last seven days on the management console.
This topic describes how to query or export the last seven days of operation records on the CTS console.
- Click Service List in the upper left corner. Under Management & Deployment, select Cloud Trace Service.
- In the left navigation pane, choose Trace List.
- Specify filters to search for your desired traces.
- Trace Type, Trace Source, Resource Type, and Search By
Select the filter from the drop-down list.
If you select Resource ID for Search By, specify a resource ID.
- Operator: Select one or more operators from the drop-down list.
- Trace Status: Available options include All trace statuses, normal, warning, and incident. You can select only one of them.
- Time range: You can query traces generated at any time range of the last seven days.
- Click
on the left of the required trace to expand its details.
- Click View Trace.
CTS Log Entries
Each log entry consists of a trace in JSON format. A log entry indicates an SMN API request, including the requested operation, the date and time, operation parameters, and information about the user who sent the request. The user information is obtained from IAM.
{ "time": "2017-02-15 14:21:50 GMT+08:00", "user": "xxx", "request": "xxx", "response": "xxx", "code": 200, "service_type": "SMN", "resource_type": "topic", "resource_id": "topicUrn instance", "source_ip": "127.0.0.1", "trace_name": "createTopic", "trace_rating": "normal", "trace_type": "ApiCall", "api_version": "2.0", "project_id": "tenantId instance", "record_time": "2017-02-15 14:21:50 GMT+08:00", "trace_id": "xxx" } { "time": "2017-02-15 14:12:15 GMT+08:00", "user": "xxx", "response": "xxx", "code": 200, "service_type": "SMN", "resource_type": "topic", "resource_id": "topicUrn instance", "source_ip": "127.0.0.1", "trace_name": "deleteTopic", "trace_rating": "normal", "trace_type": "ApiCall", "api_version": "2.0", "project_id": "tenantId instance", "record_time": "2017-02-15 14:12:15 GMT+08:00", "trace_id": "xxx" } { "time": "2017-02-13 15:38:30 GMT+08:00", "user": "xxx", "request": "xxx", "response": "xxx", "code": 200, "service_type": "SMN", "resource_type": "topic", "resource_id": "topicUrn instance", "source_ip": "127.0.0.1", "trace_name": "updateTopic", "trace_rating": "normal", "trace_type": "ApiCall", "api_version": "2.0", "project_id": "tenantId instance", "record_time": "2017-02-13 15:38:30 GMT+08:00", "trace_id": "xxx" }
