Help Center/
Scalable File Service/
User Guide (Kuala Lumpur Region)/
Typical Applications/
Enterprise Website/App Background
Updated on 2025-11-07 GMT+08:00
Context
For I/O-intensive website services, SFS Turbo can provide shared website source code directories and storage for multiple web servers, enabling low-latency and high-IOPS concurrent shared access. Features of such services are as follows:
- A large number of small files: Static website files need to be stored, including HTML files, JSON files, and static images.
- Read I/O intensive: Scope of data reading is large, and data writing is relatively small.
- Multiple web servers access an SFS Turbo background to achieve high availability of website services.
Configuration Process
- Sort out the website files.
- Log in to the SFS console. Create an SFS Turbo file system to store the website files.
- Log in to the cloud server that functions as the compute node and mount the file system.
- On the head node, upload the files to the file system.
- Start the web server.
- A VPC has been created.
- Cloud servers that function as the head node and compute node have been created and are in the created VPC.
- SFS has been enabled.
Example Configuration
- In the upper right corner of the page, click Create File System.
- On the Create File System page, set parameters as instructed.
- To mount a file system to Linux ECSs, see Mounting an NFS File System to ECSs (Linux). To mount a file system to Windows ECSs, see Mounting an NFS File System to ECSs (Windows).
- Log in to the head node and upload the files to the file system.
Parent topic: Typical Applications
