On this page
Single-batch Release
Updated on 2024-01-22 GMT+08:00
You can select a historical version configuration from the deployment record list and use the version configuration as a template to redeploy components in single-batch release mode.
In single-batch release mode, all instances are redeployed at a time. During the deployment, component services will be interrupted. This is applicable to the test deployment scenario or the deployment scenario where services are to be stopped. The deployment takes a short time.
Only components deployed in the Kubernetes environment can be redeployed in single-batch release mode.
The component version configuration that has been rolled back by referring to Rolling Back a Component cannot be used as a template to redeploy the component.
You have upgraded a component. For details, see Upgrading a Single Component or Upgrading Components in Batches.
  1. Log in to ServiceStage.
  2. Use either of the following methods to go to the Deployment Records page.
    • On the Application Management page, click the application to which the component belongs, and click the target component in Component List. In the left navigation pane, choose Deployment Records.
    • On the Component Management page, click the target component. In the left navigation pane, choose Deployment Records.
  3. In the Deployment Records list, select the deployment record of the historical version to be used as the configuration template.
  4. Click Redeploy in the upper right corner of the page. The Redeploy dialog box is displayed.
  5. Select Single-batch Release for Deployment Type and click OK.
  6. Configure the component version by referring to the following table. Parameters marked with an asterisk (*) are mandatory.
    Stack
    The value is fixed to the configuration of the selected historical version and cannot be changed.
    *Software Package/Image
    The value is fixed to the component source selected during component creation and deployment.
    If you select Source code repository, create authorization by referring to Authorizing a Repository and set the code source.
    If you select a software package, the software package type supported by the component source is determined by the selected technology stack type. For details, see Table 1.
    *Upload Method
    If the component source is software package or image package, select an uploaded software package or image package. For details about the upload method, see Component Source.
    *Command
    This parameter is mandatory if the component source is Source code repository, the component is deployed in the Kubernetes environment, and the selected technology stack type is Java, Tomcat, Node.js, Python, or PHP.
    • Default command or script: preferentially executes build.sh in the root directory. If build.sh does not exist, the code will be compiled using the common method of the selected language. Example: mvn clean package for Java.
    • Custom command: Commands are customized using the selected language. Alternatively, the default command or script is used after build.sh is modified.
      NOTICE:
      • If Custom command is selected, exercise caution when inputting sensitive information in the echo, cat, or debug command, or encrypt sensitive information to avoid information leakage.
      • To run the compilation command in the project subdirectory, you need to go to the project subdirectory and then run other script commands. For example:
        cd ./weather/
        mvn clean package
    *Dockerfile Address
    Dockerfile Address is the directory where the Dockerfile is located relative to the root directory (./) of the project. The Dockerfile is used to build an image.
    If Dockerfile Address is not specified, the system searches for the Dockerfile in the root directory of the project by default. If the Dockerfile does not exist in the root directory, the system automatically generates the Dockerfile based on the selected operating environment.
    *Component Version
    Version number of a component.
    • Automatically-generated: Click Generate. By default, the version number is the timestamp when you click Generate. The format is yyyy.mmdd.hhmms, where s is the ones place of the second in the timestamp. For example, if the timestamp is 2022.1214.172318, the version number is 2022.1214.17238.
    • You can also customize the version number in the format of A.B.C, or A.B.C.D. A. B, C, and D are natural numbers, for example, 1.0.0 or 1.0.0.0.
      NOTICE:
      • The customized version number must be unique and cannot be the same as any historical version number of the component.
    Resources
    JVM Parameters
    This parameter is available when the technology stack type is Java or Tomcat. It configures the memory size during Java code running.
    Tomcat
    This parameter is available when the technology stack type is Tomcat. It configures parameters such as the request path and port number of Tomcat.
    Advanced Settings
  7. Click Upgrade.
    In the Deployment Records area, you can view the deployment progress and wait until the deployment is complete.
