Dark Launch (Canary)
Updated on 2024-01-22 GMT+08:00
After a component is created and deployed, you can upgrade a Running or Not ready component in dark launch (canary) mode.
In dark launch (canary) mode, a certain proportion of instances are upgraded, and traffic is directed to the new version to verify whether functions of the new version are normal. Then, the remaining instances will be upgraded in rolling mode. Dark launch ensures stability of the entire system. During initial dark launch, problems can be detected and fixed.
For details about dark launch (canary) types and details, see Table 1.
Table 1 Dark launch (canary) types and description
Type
Microservice Dark Launch
Applies to ServiceComb and Spring Cloud applications. Dark launch tasks function on microservices. Multiple microservices can work together to roll out new features.
  1. The Java, Tomcat, or Docker technology stack must be selected for the component.
  2. The component must be bound to a microservice engine with security authentication disabled and multi-language access to service mesh disabled.
  3. ServiceComb 2.7.8 or later is required. Spring Cloud Huawei 1.10.4-2021.0.x or later is required.
ELB Dark Launch
Applies to ELB traffic-based components. Dark launch tasks function on ELB.
The component must be accessible from the public network and bound to an ELB.
Dark launch (canary) is supported only when the deployment environment is Kubernetes and there are two or more component instances.
For details about how to upgrade multiple components of the same application in batches, see Upgrading Components in Batches.
You have created and deployed a component. For details, see Creating and Deploying a Component.
  1. Log in to ServiceStage.
  2. Use either of the following methods to go to the component Overview page.
    • On the Application Management page, click the application to which the target component belongs, and click the component in Component List.
    • On the Component Management page, click the target component.
  3. Click Upgrade in the upper right corner of the page.
  4. Select Dark Launch (Canary) for Upgrade Type.
  5. Click Next and set the component version configuration information by referring to the following table. Parameters marked with an asterisk (*) are mandatory.
    Stack
    The value is fixed to the technology stack selected during component creation and deployment.
    *Software Package/Image
    The value is fixed to the component source selected during component creation and deployment.
    If you select Source code repository, create authorization by referring to Authorizing a Repository and set the code source.
    If you select a software package, the software package type supported by the component source is determined by the selected technology stack type. For details, see Table 1.
    *Upload Method
    If the component source is software package or image package, select an uploaded software package or image package. For details about the upload method, see Component Source.
    *Command
    This parameter is mandatory if the component source is source code, the component is deployed in the Kubernetes environment, and the selected technology stack type is Java, Tomcat, Node.js, Python, or PHP.
    • Default command or script: preferentially executes build.sh in the root directory. If build.sh does not exist, the code will be compiled using the common method of the selected language. Example: mvn clean package for Java.
    • Custom command: Commands are customized using the selected language. Alternatively, the default command or script is used after build.sh is modified.
      NOTICE:
      • If Custom command is selected, exercise caution when inputting sensitive information in the echo, cat, or debug command, or encrypt sensitive information to avoid information leakage.
      • To run the compilation command in the project subdirectory, you need to go to the project subdirectory and then run other script commands. For example:
        cd ./weather/
        mvn clean package
    *Dockerfile Address
    This parameter is mandatory if the component source is Source code repository, the component is deployed in the Kubernetes environment, and the selected technology stack type is Java, Tomcat, Node.js, Python, or PHP.
    Dockerfile Address is the directory where the Dockerfile is located relative to the root directory (./) of the project. The Dockerfile is used to build an image.
    If Dockerfile Address is not specified, the system searches for the Dockerfile in the root directory of the project by default. If the Dockerfile does not exist in the root directory, the system automatically generates the Dockerfile based on the selected operating environment.
    *Component Version
    Version number of a component.
    • Automatically-generated: Click Generate. By default, the version number is the timestamp when you click Generate. The format is yyyy.mmdd.hhmms, where s is the ones place of the second in the timestamp. For example, if the timestamp is 2022.1214.172318, the version number is 2022.1214.17238.
    • You can also customize the version number in the format of A.B.C, or A.B.C.D. A. B, C, and D are natural numbers, for example, 1.0.0 or 1.0.0.0.
      NOTICE:
      • The customized version number must be unique and cannot be the same as any historical version number of the component.
    Resources
    This parameter is available when the component is deployed in the Kubernetes environment.
    Components cannot be scheduled to nodes whose residual resources are fewer than the requested amount. For details about how to configure the request and limit parameters, see Managing Resources for Containers.
    You can customize CPU and Memory to set their quota, and change the maximum/minimum number of CPU cores and memory size (GiB) that can be used by components. To modify them, select the item to be changed and enter a new value.
    Unselected parameters indicate no restriction.
    JVM Parameters
    This parameter is available when the technology stack type is Java or Tomcat. It configures the memory size during Java code running.
    Enter the JVM parameter, for example, -Xms256m -Xmx1024m. Multiple parameters are separated by spaces.
    Tomcat
    This parameter is available when the technology stack type is Tomcat. It configures parameters such as the request path and port number of Tomcat.
    1. Select Tomcat. The Tomcat dialog box is displayed.
    1. Click Use Sample Code and edit the template file based on service requirements.
    2. Click OK.
    Advanced Settings
    Set Component Configuration, Deployment Configuration, and O&M Monitoring by referring to 10.
    Dark Launch Policy
    • Traffic Ratio: percentage of traffic directed to the new version.
    • Current Traffic Ratio: percentage of traffic directed to the current version.
    *First Batch of Dark Launch Instances
    Number of instances for dark launch in the first batch. The value range is [1, Total number of instances – 1]. Total number of instances refers to the number of running instances of the component.
    For example, if there are 6 component instances and First Batch of Dark Launch Instances is set to 1, 1 instance will be upgraded in the first batch.
    Deployment Batch with Remaining Instances
    Number of batches whose remaining instances will be upgraded.
    For example, if there are 6 component instances, First Batch of Dark Launch Instances is set to 1, and Deployment Batch with Remaining Instances is set to 3, there are 5 instances remaining to be deployed in 3 batches, and these 5 instances will be upgraded in the sequence 2:2:1.
  6. Click Upgrade.
    Wait until the component status changes from Upgrading/Rolling back to Running, indicating that the component version configuration is successfully upgraded.
Follow-Up Operations
Operation
View system monitoring
If the component is upgraded through dark launch (canary), choose System Monitoring to monitor the CPU and memory usage of instances of the dark launch version and the current version after the first batch of dark launch is complete.
Upgrade remaining instances in rolling mode
If the component is upgraded through dark launch (canary) after the first batch of dark launch is successful and the functions of the new version are normal, you can perform the following operations to upgrade the remaining component instances:
  1. Select the deployment record of the Dark Launch (Canary) type.
  2. Click Upgrade Remaining Instances in Rolling Mode.
  3. In the displayed dialog box, click OK.
    The remaining instances are upgraded to the new version based on the upgrade policy set in 5.
Roll back a component
The component version can be rolled back in the following scenarios:
  • The first batch of dark launch is complete if the component is upgraded through dark launch (canary).
  • All component instances have been upgraded to the new version.
To roll back the component configuration to the source version, refer to Rolling Back a Component.
Redeploy a component
You can select a historical version configuration from the deployment record list and use the version configuration as a template to redeploy components. For details, see Redeploying a Component.
