Accounts
Updated on 2024-01-22 GMT+08:00
You can use an account associated with the admin role to log in to the microservice engine console and create an account or manage a specified account created in the engine based on service requirements.
Table 1 Account management operations
Operation
Adding an Account
Creates an account and associates a proper role with the account. Users who use the account have the access and operation permissions on the microservice engine.
You can create up to 1000 accounts.
Viewing Role Permissions
Displays the permissions of the role associated with a specified account.
Editing an Account
Adds or deletes roles for an account. The root account cannot be edited.
Changing the Password
Changes the password of an account that has logged in to the microservice engine based on service requirements or security regulations.
NOTICE:
  • If the account and password are used to register a microservice in the SDK, changing the account and password may affect the service running of the microservice (the microservice cannot be registered with the microservice engine). As a result, the service system will be damaged. Exercise caution when performing this operation.
  • After the password is changed, update the microservice authentication configuration in a timely manner.
  • After the password is changed, the account may be locked due to three consecutive incorrect password attempts. The account will be unlocked after 15 minutes.
Deleting an Account
Deletes an account that is no longer used. The root account cannot be deleted.
NOTICE:
If the account and password are used to register a service in the SDK, deleting the account will affect the service running (the account cannot be registered with the engine) and damage the service system. Exercise caution when performing this operation.
Adding an Account
Before adding an account, you can create a role based on service requirements. For details, see Creating a Role.
  1. Log in to ServiceStage and choose Cloud Service Engine > Engines.
  2. Select the target microservice engine with security authentication enabled from the Microservice Engine drop-down list in the upper part of the page.
  3. Choose System Management.
  4. In the displayed Security Authentication dialog box, enter the name and password of the account associated with the admin role under the microservice engine, and click OK.
  5. Choose Accounts > Create Account and configure account parameters by referring to the following table:
    Account
    Enter an account name.
    The account name cannot be changed after the account is created.
    Role
    Select a role based on service requirements.
    An account can be associated with up to five roles.
    Password
    Enter the password.
    Confirm Password
    Enter the password again.
  6. Click OK.
  5. Click the role in the Role column of the account to be viewed in the account list. On the displayed page, view the role and permission configuration associated with the account.
Editing an Account
  5. On the Accounts tab page, click Edit Account in the Operation column of the account to be edited.
  6. Select a role based on service requirements.
  7. Click Save.
  4. In the displayed Security Authentication dialog box, enter the account name and password, and click OK.
    • If you connect to the microservice engine for the first time, enter the account name root and the password entered when creating the microservice engine.
    • The account for connecting to the microservice engine is not associated with the admin role. You can only change the password of the current login account.
    • The account for connecting to the microservice engine is associated with the admin role. You can change the passwords of all accounts of the microservice engine.
    • For details about how to create an account, see Adding an Account.
  5. On the Accounts tab page, select the account for logging in to the microservice engine and click Reset Own Password in the Operation column.
    1. Enter the old password and a new password, and confirm the password.
    2. After confirming that the password needs to be changed, select I Understand.
    You can also click Reset Own Password in the upper right corner of the System Management page to change the password of the current login account.
  1. Click Save.
Deleting an Account
  5. On the Accounts tab page, click Delete in the Operation column of the account to be deleted.
  6. Click OK.
