Governing Microservices
Updated on 2024-01-22 GMT+08:00
After a microservice is deployed, you can govern it based on its running statuses.
  • You can create a microservice in Microservice List from Service Catalog and start the microservice. After the microservice starts, the service instance is registered under the corresponding service based on configurations in the .yaml file.
  • If the microservice is not created in advance or has been deleted, the microservice is automatically created when the service instance is registered.
  • After a microservice is created, register the service instance before performing the corresponding operation.
Governance Policies
You can configure the following policies: Load Balancing, Rate Limiting, Fault Tolerance, Service Degradation, Circuit Breaker, Fault Injection, and Blacklist and Whitelist. For details, see the following table.
Name
Load Balancing
  • Application scenario
    Generally, multiple instances are deployed for a microservice. Load balancing controls the policy for a microservice consumer to access multiple instances of a microservice provider to balance traffic. It includes polling, random, response time weight, and session stickiness.
Rate Limiting
    This policy controls the number of requests for accessing microservices to prevent the system from being damaged due to traffic impact.
Service Degradation
    When a microservice invokes other microservices, the default value is forcibly returned or an exception is thrown instead of sending the request to the target microservice. In this way, the access to the target microservice is shielded and the pressure on the target microservice is reduced.
Fault Tolerance
    If an exception occurs when a microservice consumer accesses a provider, for example, the instance network is disconnected, the request needs to be forwarded to another available instance. Fault tolerance is often referred to as retry.
Circuit Breaker
    If an exception occurs when a microservice consumer accesses a provider, for example, the instance network is disconnected or the request times out, and the exception accumulates to a certain extent, the consumer needs to stop accessing the provider and return an exception or a default value to prevent the avalanche effect.
    Circuit breaker provides automatic circuit breaker. Automatic circuit breaker determines whether to trigger circuit breaker based on the error rate.
Fault Injection
    Fault injection can simulate an invoking failure, which is mainly used for function verification and fault scenario demonstration.
  • Governance of microservices accessed through Java chassis.
This policy applies only to microservices accessed through Java chassis.
    Based on the public key authentication mechanism, CSE provides the blacklist and whitelist functions. The blacklist and whitelist can be used to control which services can be accessed by microservices.
    The blacklist and whitelist take effect only after public key authentication is enabled. For details, see Configuring Public Key Authentication.
Configuring Load Balancing
  1. Log in to ServiceStage and choose Cloud Service Engine > Engines.
  2. Select the target microservice engine from the Microservice Engine drop-down list in the upper part of the page.
  3. Choose Microservice Governance.
    • For microservice engines with security authentication disabled, go to 5.
    • For microservice engines with security authentication enabled, go to 4.
  4. In the displayed Security Authentication dialog box, enter the account name and password, and click OK.
  5. Click the microservice to be governed.
  6. Choose Load Balancing.
  7. Click New. Select the microservices to be governed and select a proper load balancing policy. For details, see the following table.
    Figure 1 Configuring load balancing (for microservices accessed through Spring Cloud)
    Figure 2 Configuring load balancing (for microservices accessed through Java chassis)
    Policy
    Round robin
    Supports routes according to the location information about service instances.
    Random
    Provides random routes for service instances.
    Response time weigh
    This policy applies to microservices accessed through Java chassis.
    Provides weight routes with the minimum active number (latency) and supports service instances with slow service processing in receiving a small number of requests to prevent the system from stopping response. This load balancing policy is suitable for applications with low and stable service requests.
    Session stickiness
    Provides a mechanism on the load balancer. In the specified session stickiness duration, this mechanism allocates the access requests related to the same user to the same instance.
    • Stickiness Duration: time limit for keeping a session. The value ranges from 0 to 86400, in seconds.
    • Failures: number of access failures. The value ranges from 0 to 10. If the upper limit of failures or the session stickiness duration exceeds the specified values, the microservice stops accessing this instance.
  8. Click OK.
Configuring Rate Limiting
  6. Click Rate Limiting.
  7. Click New. The following table describes configuration items of rate limiting.
    Figure 3 Configuring rate limiting (for microservices accessed through Spring Cloud)
    Figure 4 Configuring rate limiting (for microservices accessed through Java chassis)
    Configuration Item
    Value Range
    Rate Limiting Object
    This configuration applies to microservices accessed through Java chassis.
    Other microservices that access the microservice.
    Select an item from the drop-down list next to Rate Limiting Object.
    Upstream Microservice
    This configuration applies to microservices accessed through Spring Cloud.
    Configure rate limiting for the upstream microservice to invoke the service.
    Select an item from the drop-down list next to Upstream Microservice.
    QPS
    Requests generated per second. When the number of requests sent by the rate limiting object to the current service instance exceeds the specified value, the current service instance no longer accepts requests from the rate limiting object.
    Enter an integer ranging from 1 to 99999.
    If a microservice has three instances, the rate limiting of each instance is set to 2700 QPS, then the total QPS is 8100, and rate limiting is triggered only when the QPS exceeds 8100.
  8. Click OK.
Configuring Service Degradation
  6. Click Service Degradation.
  7. Click New and select a proper policy. The following table describes the configuration items of service degradation.
    Figure 5 Configuring service degradation (for microservices accessed through Spring Cloud)
    Figure 6 Configuring service degradation (for microservices accessed through Java chassis)
    Configuration Item
    Fallback Object
    Microservice to be degraded.
    Request Path
    Click and set Method, Path, and Headers to specify the request path.
    Fallback
    • Open
    • Close
  8. Click OK.
Configuring Fault Tolerance
  6. Click Fault Tolerance.
  7. Click New and select a proper policy. The following table describes the configuration items of fault tolerance.
    Figure 7 Configuring fault tolerance (for microservices accessed through Spring Cloud)
    Figure 8 Configuring fault tolerance (for microservices accessed through Java chassis)
    Configuration Item
    Downstream Microservice
    Configure fault tolerance for the microservice to invoke the downstream microservice. You can select a value from the drop-down list.
    Fault Tolerance Object
    Microservice or method that the application relies on.
    Fault Tolerance
    Open: The system processes a request sent to the fault tolerance object based on the selected fault tolerance policy when the request encounters an error.
    Close: The system waits until the timeout interval expires and then returns the failure result even though the service request fails to be implemented.
    FT Policy
    This parameter is mandatory when Fault Tolerance is set to Open.
    For microservices accessed through Spring Cloud, set the following parameters:
    • Number of attempts to the same microservice instance
    • Number of attempts to the new microservice instance
    For microservices accessed through Java chassis, set the following parameters:
    • Failover
      The system attempts to reestablish connections on different servers.
    • Failfast
      The system does not attempt to reestablish a connection. After a request fails, a failure result is returned immediately.
    • Failback
      The system attempts to reestablish connections on the same server.
    • custom
      • Number of attempts to reestablish connections on the same server
      • Number of attempts to reestablish connections on new servers
  8. Click OK.
Configuring Circuit Breaker
  6. Click Circuit Breaker.
  7. Click New and select a proper policy. The following table describes the configuration items of circuit breaker.
    Figure 9 Configuring circuit breaker (for microservices accessed through Spring Cloud)
    Figure 10 Configuring circuit breaker (for microservices accessed through Java chassis)
    Configuration Item
    Configure circuit breaker for the microservice to invoke the downstream microservice.
    Fallbreak Object
    Microservice or method invoked by the application.
    Request Path
    Triggering Condition
    • Circuit Breaker Time Window: circuit breaker duration. The system does not respond to requests within this time window.
    • Request Failure Rate: failure rate of window requests.
    • Window Requests: number of requests received by the window. Circuit breaker is triggered only when Request Failure Rate and Window Requests both reach their thresholds.
  8. Click OK.
Configuring Fault Injection
  6. Click Fault Injection.
  7. Click New and select a proper policy. The following table describes the configuration items of fault injection.
    Figure 11 Configuring fault injection (delayed)
    Figure 12 Configuring fault injection (fault)
    Configuration Item
    Injection Object
    Microservices for which fault injection is required. You can specify a method for this configuration item.
    Type
    Type of the fault injected to the microservice.
    • Delayed
    • Fault
    Protocol
    Protocol for accessing the microservice when latency or fault occurs.
    • Rest
    • Highway
    Occurrence Probability
    Probability of latency or fault occurrence.
    Delay Time
    Duration of the latency during microservice access. This parameter is required when Type is set to Delayed.
    HTTP Error Code
    HTTP error code during microservice access. This parameter is required when Type is set to Fault. This error code is an HTTP error code.
  8. Click OK.
Configuring Blacklist and Whitelist
  6. Click Black and white list.
  7. Click New to add a blacklist or whitelist for the application. The following table describes configuration items of blacklist and whitelist.
    Figure 13 Configuring blacklist and whitelist
    Configuration Item
    Type
    • Blacklist: Microservices that match the matching rule are not allowed to access the current service.
    • Whitelist: Microservices that match the matching rule are allowed to access the current service.
    Rule
    Use a regular expression.
    For example, if Rule is set to data*, services whose names start with data in the blacklist are not allowed to access the current service, or services whose names start with data in the whitelist are allowed to access the current service.
  8. Click OK.
Public key authentication is a simple and efficient authentication mechanism between microservices provided by CSE. Its security is based on the reliable interaction between microservices and the service center. That is, the authentication mechanism must be enabled between microservices and the service center. The procedure is as follows:
  1. When the microservice starts, a key pair is generated and the public key is registered with the service center.
  2. Before accessing the provider, the consumer uses its own private key to sign a message.
  3. The provider obtains the public key of the consumer from the service center and verifies the signed message.
To enable public key authentication, perform the following steps:
  1. Enable public key authentication for both the consumer and provider.
    servicecomb:
      handler:
        chain:
          Consumer:
            default: auth-consumer
          Provider:
            default: auth-provider
  2. Add the following dependency to the pom.xml file:
    <dependency>
        <groupId>org.apache.servicecomb</groupId>
        <artifactId>handler-publickey-auth</artifactId>
      </dependency>
