Binding an EIP
Exclusive microservice engines that are bound with EIPs can be accessed from the public network.
Microservice engines that do not have security authentication enabled do not have the authentication and authorization capabilities. Opening those microservice engines to the public network may cause security risks and increases the system vulnerability. For example, data assets such as configurations and service information may be stolen.
Do not use this function in a production environment or a network environment with high security requirements.
An EIP has been created.
For details about how to create an EIP, see Assigning an EIP and Binding It to an ECS.
- Log in to ServiceStage and choose Cloud Service Engine > Engines.
- Select the target microservice engine from the Microservice Engine drop-down list in the upper part of the page.
- In the Network Configuration and Security area, click Bind EIP.
- Read the security risk prompt in the displayed dialog box and select I understand the security risks.
- In the EIP drop-down list, select the EIP to be bound.
- Click OK.
