Help Center/
      ServiceStage/
        User Guide (Kuala Lumpur Region)/
        Component Management/
      Viewing the Component Running Environment
        Updated on 2024-01-22 GMT+08:00
After a component is successfully deployed, you can view the resources (such as CCE clusters and microservice engines) on which the component depends and the resource status and usage on the component Infrastructure page.
- Log in to ServiceStage.
 - Use either of the following methods to go to the Infrastructure page.
- On the Application Management page, click the application to which the component belongs, and click the target component in Component List. In the left navigation pane, choose Infrastructure.
 - On the Component Management page, click the target component. In the left navigation pane, choose Infrastructure.
 - On the component Infrastructure page, select component running resources and view the resource status and usage.
   Parent topic: Component Management
