Component Overview
Updated on 2024-01-22 GMT+08:00
A component is a service feature implementation of an application. It is carried by software packages and can be independently deployed and run.
After creating an application on ServiceStage, you can add components to the application. A maximum of 1000 components can be created for an application.
You can set the component technology stack and component source based on service requirements to create and deploy components.
Technology Stack
A technology stack includes the operating system, framework, and runtime on which component running depends. It consists of attributes such as the stack name, type, status, and version. The version number complies with the semantic versioning specifications.
ServiceStage provides and manages the stack lifecycle. You only need to focus on service development to improve application hosting experience.
The lifecycle phases of the technology stack are defined as follows:
  • Preview: The beta version is released.
  • General Availability (GA): The official version is released.
  • End of Life (EOL): The lifecycle ends.
The technology stack status is defined as follows:
  • Preview: The stack is in the Preview phase.
  • Supported: The stack is in the GA phase.
  • Deprecated: The stack is in the GA phase but the EOL announcement has been released, or the stack is not recommended by ServiceStage.
For details about the technology stack, see Table 1.
Table 1 Technology stack information
Technology Stack
Type
Status
Release Description
Component Source and Deployment Mode
OpenJDK8
Java
Supported
The component source can be source code or JAR package, and container-based deployment is supported. For details, see Deploying a Component.
Tomcat8/OpenJDK8
Tomcat
Supported
The component source can be source code or WAR package, and container-based deployment is supported. For details, see Deploying a Component.
Tomcat9/OpenJDK8
Tomcat
Supported
Node.js8
Node.js
Supported
The component source can be source code or ZIP package, and container-based deployment is supported. For details, see Deploying a Component.
Node.js14
Node.js
Supported
Node.js16
Node.js
Supported
Docker
Docker
Supported by CCE.
The component source is from image package, and container-based deployment is supported. For details, see Deploying a Component.
Python3
Python
Php7
Php
Component Source
Component Source
Source Code Repository
Create authorization by referring to Authorizing a Repository and set the code source.
JAR package
The following upload modes are supported:
Select the corresponding software package from OBS. Upload the software package to the OBS bucket in advance. For details, see Uploading a File.
WAR package
ZIP package
Image package
Containerized applications need to be created based on images. My Images (private images) and Third-party Images are supported.
  • If you select My Images, upload the image to the image repository in advance. For details, see Uploading an Image.
  • If you select Third-party Images, ensure that you have obtained the address of the third-party image. The format of the image address is as follows:
    {IP address of the third-party image repository}:{Port number for accessing the third-party image repository}/{Image storage path}/{Image name}:{Image tag}
    Alternatively:
    If the image tag is not specified, the latest version is used by default.
    Currently, only third-party public images can be obtained.
Deployment Mode
Container-based deployment
Cloud Container Engine (CCE) deployment: CCE is a highly scalable, enterprise-class hosted Kubernetes service for you to run containers and applications. With CCE, you can easily deploy, manage, and scale containerized applications on the cloud platform.
