Permissions Management
Updated on 2024-08-05 GMT+08:00
If you need to assign different permissions to employees in your enterprise to access your ServiceStage resources, IAM is a good choice for fine-grained permissions management. IAM provides identity authentication, permissions management, and access control, helping you secure access to your resources.
With IAM, you can use your cloud service account to create IAM users for your employees, and assign permissions to the users to control their access to specific resource types. For example, some software developers in your enterprise need to use ServiceStage resources but must not delete them or perform any high-risk operations. To achieve this result, you can create IAM users for the software developers and grant them only the permissions required for using ServiceStage resources.
If your cloud service account does not need individual IAM users for permissions management, you may skip over this chapter.
IAM can be used free of charge. You pay only for the resources in your account. For details, see IAM Service Overview
ServiceStage Permissions
By default, new IAM users do not have any permissions assigned. You need to add a user to one or more groups, and assign permissions policies to these groups. The user then inherits permissions from the groups it is a member of. This process is called authorization. After authorization, the user can perform specified operations on ServiceStage based on the granted permissions policies.
ServiceStage is a project-level service deployed and accessed in specific physical regions. To assign ServiceStage permissions to a user group, specify the scope as region-specific projects and select projects for the permissions to take effect. If All projects is selected, the permissions will take effect for the user group in all region-specific projects. When accessing ServiceStage, the users need to switch to a region where they have been authorized to use cloud services.
You can grant users permissions by using roles and policies.
  • Roles: A type of coarse-grained authorization mechanism that defines permissions related to user responsibilities. This mechanism provides only a limited number of service-level roles for authorization. When using roles to grant permissions, you also need to assign other roles on which the permissions depend to take effect. However, roles are not an ideal choice for fine-grained authorization and secure access control.
  • Policies are a type of fine-grained authorization mechanism that defines permissions required to perform operations on specific cloud resources under certain conditions. This mechanism allows for more flexible policy-based authorization, meeting requirements for secure access control.
Table 1 lists all the system policies supported by ServiceStage. System policies are recommended. System roles are used only for compatibility with existing permission configurations.
Table 1 ServiceStage system permissions
Role/Policy Name
Type
Depended System Permissions
ServiceStage FullAccess
Full permissions for ServiceStage.
System-defined policy
None
ServiceStage ReadOnlyAccess
Read-only permissions for ServiceStage.
None
ServiceStage Developer
ServiceStage developer,
who has permissions for operating applications, components, and environments, but excluding permissions for creating basic resources.
None
CSE Admin
Administrator permissions for CSE.
None
CSE Viewer
View permissions for CSE.
None
ServiceStage Administrator
ServiceStage administrator, who has full permissions for this service.
System-defined role
CCE administrator, VPC administrator, SWR administrator, Server administrator, and OBS administrator.
ServiceStage Operator
ServiceStage operator, who has the read-only permission for this service.
System-defined role
ServiceStage developer, who has full permissions for this service.
System-defined role
If these policies do not meet actual requirements, you can customize policies based on Table 2 and Table 3. For more information, see Creating a Custom Policy.
Table 2 Common ServiceStage operations supported by each system policy
Operation
Creating an application
x
Modifying an application
x
Querying an application
Deleting an application
x
Creating a component
x
Searching for a component
Deploying a component
x
Maintaining a component
x
Deleting a component
x
Creating a build job
x
Modifying a build job
x
Querying a build job
Starting a build job
x
Deleting a build job
x
Creating a pipeline
x
Modifying a pipeline
x
Querying a pipeline
Starting a pipeline
x
Cloning a pipeline
x
Deleting a pipeline
x
Creating repository authorization
x
Modifying repository authorization
x
Querying repository authorization
Deleting repository authorization
x
Table 3 Common CSE operations supported by each system policy
Operation
CSE Viewer
CSE Admin
Creating a microservice engine
x
Maintaining a microservice engine
x
Querying a microservice engine
Deleting a microservice engine
x
x
x
x
Creating microservice configurations
x
Querying microservice configurations
Editing microservice configurations
x
Deleting microservice configurations
x
Creating a microservice governance policy
x
Querying a microservice governance policy
Editing a microservice governance policy
x
Deleting a microservice governance policy
x
Fine-grained permissions
  • SWR does not support fine-grained permissions. Related permissions need to be authorized separately.
To use a custom fine-grained policy, log in to the IAM console as an administrator and select the desired fine-grained permissions for ServiceStage and CSE.
  • Table 4 describes fine-grained permission dependencies of CSE.
  • Table 5 describes fine-grained permission dependencies of ServiceStage.
Table 4 Fine-grained permission dependencies of CSE
Permission Name
Permission Dependency
Application Scenario
cse:engine:list
Lists all microservice engines.
None
Engine list view
cse:engine:get
Views engine information.
cse:engine:list
Engine details view (supported by only exclusive microservice engines)
cse:engine:modify
Modifies an engine.
  • cse:engine:list
  • cse:engine:get
Engine modification, including enabling or disabling public access, enabling or disabling security authentication, and retrying failed tasks, supported by only exclusive microservice engines
cse:engine:upgrade
Upgrades an engine.
  • cse:engine:list
  • cse:engine:get
Engine upgrade, including upgrading the engine version, supported by only exclusive microservice engines.
cse:engine:delete
Deletes an engine.
  • cse:engine:list
  • cse:engine:get
  • vpc:ports:get
  • vpc:ports:delete
Engine deletion (supported by only exclusive microservice engines.)
cse:engine:create
Creates an engine.
  • cse:engine:get
  • cse:engine:list
  • ecs:cloudServerFlavors:get
  • vpc:vpcs:get
  • vpc:vpcs:list
  • vpc:subnets:get
  • vpc:ports:get
  • vpc:ports:create
Engine creation, including creating an engine and creating a backup or restoration task, supported by only exclusive microservice engines.
cse:config:modify
Modifies configuration and management functions.
  • cse:engine:list
  • cse:engine:get
  • cse:config:get
Modification on global and governance configurations
cse:config:get
Views configuration and management functions.
  • cse:engine:list
  • cse:engine:get
Service configuration view
cse:governance:modify
Modifies the governance center.
  • cse:engine:list
  • cse:engine:get
  • cse:config:get
  • cse:config:modify
  • cse:registry:get
  • cse:registry:modify
  • cse:governance:get
Service governance creation and modification
cse:governance:get
Views the governance center.
  • cse:engine:list
  • cse:engine:get
  • cse:config:get
  • cse:registry:get
Service governance view
cse:registry:modify
Modifies service registry and management.
  • cse:engine:list
  • cse:engine:get
  • cse:registry:get
Service modification
cse:dashboard:modify
Modifies the dashboard.
  • cse:engine:list
  • cse:engine:get
  • cse:registry:get
  • cse:dashboard:get
Dashboard modification
cse:dashboard:get
Views the dashboard.
  • cse:engine:list
  • cse:engine:get
  • cse:registry:get
Dashboard view
cse:registry:get
Views service registry and management.
  • cse:engine:list
  • cse:engine:get
Service catalog view
The dashboard does not need to be authenticated but requires registry permissions, because it uses the service catalog function to distinguish services.
Table 5 Fine-grained permission dependencies of ServiceStage
Permission Name
servicestage:app:get
Views application information.
servicestage:app:list
Application information view
servicestage:app:create
Creates an application.
  • servicestage:app:get
  • servicestage:app:list
  • servicestage:assembling:get
  • servicestage:assembling:list
  • servicestage:assembling:create
Application creation
servicestage:app:modify
Updates an application.
  • servicestage:assembling:modify
Application update
servicestage:app:delete
Deletes an application.
  • servicestage:assembling:delete
Application deletion
Views the environment and application list.
None
Environment and application list view
servicestage:environment:create
Creates an environment.
Environment creation
servicestage:environment:modify
Updates an environment.
Environment update
servicestage:environment:delete
Deletes an environment.
Environment deletion
Views the build information.
Build information view
Creates a build job.
Build job creation.
Modifies a build job.
Build job modification
Deletes a build job.
Build job deletion
Views the build list.
None
Build list view
