Data Collection Process
The following figure shows the log data collection process.
       No.  |
       Step  |
       Description  |
       1  |
       Select or purchase an ECS and install the component controller on the ECS to complete node management.  |
       2  |
       Install data collection engine Logstash on the Components tab to complete component installation.  |
       3  |
       Configure the source and destination connectors. Select a connector as required and set parameters.  |
       4  |
       Configure codeless parsers on the console based on your needs.  |
       5  |
       Configure the connection channels, associate it with a node, and deliver the Logstash pipeline configuration to complete the data collection configuration.  |
       6  |
       After the collection channel is configured, check whether data is collected. If logs are sent to the SecMaster pipeline, you can query the result on the SecMaster Security Analysis page.  |
Data Collection Configuration Removal Process
        No.  |
        Step  |
        Description  |
        1  |
        Deleting a collection channel  |
        On the Collection Channels page, stop and delete the Logstash pipeline configuration. Note: All collection channels on related nodes must be stopped and deleted first.  |
        2  |
        (Optional) Deleting a parser  |
        If a parser is configured, delete it from the Parsers tab.  |
        3  |
        (Optional) Deleting a data connection  |
        If a data connection is added, delete the source and destination connectors from the Connections tab.  |
        4  |
        Removing a component  |
        Delete the collection engine Logstash installed on the node and remove the component.  |
        5  |
        Deregistering a node  |
        Remove the component controller to complete node deregistration. Note: Deregistering a node does not delete the ECS and endpoint resources. If the data collection function is no longer used, you need to manually release the resources.  |
